The ICUSB2322I 2-Port Industrial USB to Serial Hub with DIN Rail Clips converts a single USB port into two RS232 serial ports, enabling you to connect to, monitor and control your serial devices.
Featuring rugged metal construction, with sturdy wall-mounting brackets and top-hat DIN Rail clips (included), this USB to Serial Hub provides versatile mounting options and a robust solution for both harsh industrial environments and simple desktop installations.
This USB powered adapter also retains assigned serial COM port values once connected, allowing the same values to be automatically reassigned to the ports provided by the adapter.
Durable construction
The sturdiness of the adapter is designed to withstand harsh environments, ensuring longevity and reliability in industrial settings. -
Versatile connectivity
Two RS-232 ports allow the connection of multiple serial devices, enhancing productivity and flexibility for industrial applications. -
Easy installations
Wall-mountable and compatible with DIN rails, this adapter provides convenient installation options for various settings. -
Efficient power usage
Being USB-powered enables this adapter to operate efficiently while minimizing the need for external power sources. -
High data transfer rate
With a data transfer rate of 921.6 Kbps, this adapter ensures fast and reliable communication between connected devices.
- StarTech.com USB to Serial Adapter - 2 Port - Wall Mount - Din Rail Clips - Industrial - COM Port Retention - FTDI - DB9 (ICUSB2322I) - serial adapter - USB 2.0 - RS-232 x 2
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- RS-232 x 2
- 5.6 cm x 10.4 cm x 2.5 cm
- 400 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- Processor
- FTDI
- Black
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- Status Indicators
- Link/activity
- USB powered, wall mountable, rugged, DIN rail mountable
Processor / Memory
- Processor
- FTDI
- 2 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Plug and Play, RoHS
- Black
- OS Required
- 5.6 cm
- 10.4 cm
- 2.5 cm
- 400 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.73 |
StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £18.08 |
StarTech.com 1 Port Metal Industrial USB to RS422/RS485 Serial Adapter with Isolation | In Stock | £110.45 |
StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 1 - M/F | In Stock | £6.62 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.85 |
StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £45.96 |
StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips | In Stock | £52.85 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £25.85 |
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £88.60 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £151.52 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.28 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £78.51 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £212.24 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £340.65 |
