StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips
Quicklinx: 837XWS00 Mfr#: ICUSB2322I
Type: Serial adapter
Compatibility: PC, Mac
Interface: USB 2.0
More than 50 In Stock
£54.71 ex VAT
£65.65 inc VAT
The ICUSB2322I 2-Port Industrial USB to Serial Hub with DIN Rail Clips converts a single USB port into two RS232 serial ports, enabling you to connect to, monitor and control your serial devices.
Featuring rugged metal construction, with sturdy wall-mounting brackets and top-hat DIN Rail clips (included), this USB to Serial Hub provides versatile mounting options and a robust solution for both harsh industrial environments and simple desktop installations.
This USB powered adapter also retains assigned serial COM port values once connected, allowing the same values to be automatically reassigned to the ports provided by the adapter.
StarTech.com USB to Serial Adapter - 2 Port - Wall Mount - Din Rail Clips - Industrial - COM Port Retention - FTDI - DB9 (ICUSB2322I) - serial adapter - USB 2.0 - RS-232 x 2
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 2
5.6 cm x 10.4 cm x 2.5 cm
400 g
RS-232
Data Transfer Rate
921.6 Kbps
FTDI
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
Serial adapter
External
USB 2.0
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Status Indicators
Link/activity
USB powered, wall mountable, rugged, DIN rail mountable
Processor / Memory
FTDI
2 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB 2.0 - 4 pin USB Type B
Plug and Play, RoHS
5.6 cm
10.4 cm
2.5 cm
400 g
55 °C
5 - 95%
837X StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £22.01
837X StarTech.com 4 Port Black USB 2.0 Hub In Stock £18.58
837X StarTech.com 1 Port Metal Industrial USB to RS422/RS485 Serial Adapter with Isolation In Stock £107.76
837X StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 1 - M/F In Stock £6.52
837X StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.62
837X StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £47.27
837X StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips In Stock £54.71
837X StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £25.80
837X StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £91.11
837X StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £152.14
837X StarTech.com USB to RS232 Serial Adapter In Stock £16.69
837X StarTech.com 4 Port USB to Serial Hub In Stock £78.99
837X StarTech.com 4-Port USB to Serial Adapter In Stock £218.26
837X StarTech.com 8-Port USB to Serial Adapter In Stock £350.31
Compatibility: PC
Compatibility: Mac
Interface: USB 2.0
