This 2-port USB-C / USB-A KVM enables you to easily switch between a USB Type-C or Thunderbolt 3 desktop/laptop computer and a USB-A and HDMI desktop/laptop computer, using a single keyboard, HDMI monitor and mouse.
Easy to Setup and Use
Utilizing USB-C with DP alt-mode and USB-A and HDMI this compact KVM switch only requires three host cable connections, ensuring a small footprint with limited cabling requirements. All required cables for connecting your computers are included, to ensure a hassle-free setup right out of the box. For easy operation, the KVM features a single button that toggles between connected computers. -
Supports 4K 60Hz Resolutions
The USB-C KVM switch supports UHD resolutions up to 4K (3840 x 2160) at 60Hz and can drive one large HDMI 2.0 display with ease, maximizing viewing space. -
Compact and Portable
Along with the USB-C design that ensures cabling requirements are minimum the KVM is bus powered further reducing clutter by avoiding the need for a bulky power adapter. The lightweight small form factor makes this mini KVM switch easy to deploy and is ideal for mobile/hot desk workforces. -
Guaranteed Compatibility
The KVM is OS independent supporting all operating systems including Windows, Linux, macOS, iOS (Apple iPad Pro) and Android. StarTech.com has rigorously tested this product to ensure compatibility with all popular device brands including: Dell, HP, Apple and Lenovo. The SV221HUC4K is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 2 Port Hybrid USB-A + HDMI & USB-C KVM Switch, Single 4K 60Hz HDMI 2.0 Monitor, Compact Desktop and/or Laptop HDMI KVM Switch, USB Bus Powered, Thunderbolt 3 Compatible - 2 Port HDMI KVM Switch (SV221HUC4K) - KVM / audio switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- Plastic housing
- 13.8 cm x 7 cm x 1.5 cm
- 200 g
- Black
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Plastic housing
- Status Indicators
- Port status, host
- 2 x USB 2.0 Type A console , 1 x HDMI console , 1 x HDMI , 1 x micro-USB Type B , 1 x USB 2.0 Type C
- Black
- Cables Included
- USB-C cable - 1 m , USB-A to Micro-USB Type B cable - 1 m , HDMI cable - 1 m
- MTBF
- 50,000 hours
- RoHS, WEEE, FCC, RCM, DisplayPort 1.2
- 13.8 cm
- 7 cm
- 1.5 cm
- 200 g
- Shipping Width
- 12 cm
- Shipping Depth
- 17.2 cm
- Shipping Height
- 8.5 cm
- Shipping Weight
- 250 g
- Limited warranty - 2 years
- 5 °C
- 55 °C
- 20 - 80% RH
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 50 °C
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.54 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £22.81 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £13.20 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.44 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £8.81 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £25.63 |
StarTech.com 1m USB C Cable - USB 3.0 | In Stock | £7.54 |
StarTech.com 0.5m USB C Cable - USB 3.1 | In Stock | £12.46 |
StarTech.com 1.8m USB 3.1 5Gbps with PD (5A) C to C Cable - M/M Certified | In Stock | £24.69 |
StarTech.com USB-C KVM Switch, 4K 60Hz | In Stock | £146.60 |
