StarTech.com 2 Port Hybrid USB-C KVM Switch
Quicklinx: GKNKWS00 Mfr#: SV221HUC4K
Type: KVM / audio switch
Ports: 2
Connectivity: KVM
12 In Stock
£36.54 ex VAT
£43.84 inc VAT
This 2-port USB-C / USB-A KVM enables you to easily switch between a USB Type-C or Thunderbolt 3 desktop/laptop computer and a USB-A and HDMI desktop/laptop computer, using a single keyboard, HDMI monitor and mouse.
  • Easy to Setup and Use
    Utilizing USB-C with DP alt-mode and USB-A and HDMI this compact KVM switch only requires three host cable connections, ensuring a small footprint with limited cabling requirements. All required cables for connecting your computers are included, to ensure a hassle-free setup right out of the box. For easy operation, the KVM features a single button that toggles between connected computers.
  • Supports 4K 60Hz Resolutions
    The USB-C KVM switch supports UHD resolutions up to 4K (3840 x 2160) at 60Hz and can drive one large HDMI 2.0 display with ease, maximizing viewing space.
  • Compact and Portable
    Along with the USB-C design that ensures cabling requirements are minimum the KVM is bus powered further reducing clutter by avoiding the need for a bulky power adapter. The lightweight small form factor makes this mini KVM switch easy to deploy and is ideal for mobile/hot desk workforces.
  • Guaranteed Compatibility
    The KVM is OS independent supporting all operating systems including Windows, Linux, macOS, iOS (Apple iPad Pro) and Android. StarTech.com has rigorously tested this product to ensure compatibility with all popular device brands including: Dell, HP, Apple and Lenovo. The SV221HUC4K is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 2 Port Hybrid USB-A + HDMI & USB-C KVM Switch, Single 4K 60Hz HDMI 2.0 Monitor, Compact Desktop and/or Laptop HDMI KVM Switch, USB Bus Powered, Thunderbolt 3 Compatible - 2 Port HDMI KVM Switch (SV221HUC4K) - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
Plastic housing
13.8 cm x 7 cm x 1.5 cm
200 g
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Plastic housing
Status Indicators
Port status, host
2 x USB 2.0 Type A console , 1 x HDMI console , 1 x HDMI , 1 x micro-USB Type B , 1 x USB 2.0 Type C
USB-C cable - 1 m , USB-A to Micro-USB Type B cable - 1 m , HDMI cable - 1 m
MTBF
50,000 hours
RoHS, WEEE, FCC, RCM, DisplayPort 1.2
13.8 cm
7 cm
1.5 cm
200 g
Shipping Width
12 cm
Shipping Depth
17.2 cm
Shipping Height
8.5 cm
Shipping Weight
250 g
5 °C
55 °C
20 - 80% RH
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
GKNK StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £22.45
GKNK StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops In Stock £6.77
GKNK StarTech.com HDMI to DisplayPort Converter - 4K In Stock £36.91
GKNK StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
GKNK StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.87
GKNK StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.59
GKNK StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £26.27
GKNK StarTech.com 1m USB C Cable - USB 3.0 In Stock £11.26
GKNK StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £12.76
GKNK StarTech.com 1.8m USB 3.1 5Gbps with PD (5A) C to C Cable - M/M Certified In Stock £26.11
GKNK StarTech.com USB-C KVM Switch, 4K 60Hz In Stock £150.27
Ports: 2
Connectivity: KVM
