StarTech.com 2-Port Hybrid Cable KVM Switch
Quicklinx: HDG6WS00 Mfr#: C2-H46-UAC-CBL-KVM
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 2
Hurry, only 2 left in stock!
£43.89 ex VAT
£52.66 inc VAT
This Hybrid KVM Switch enables users to switch between a USB Type-A and HDMI-enabled desktop and a USB Type-C (DP Alt-Mode) enabled laptop, to share a keyboard, mouse, audio input/output devices, and a single 4K 60Hz HDMI monitor.
  • Hassle-Free Setup
    The KVM switch is bus powered and features built-in HDMI, USB-A, USB-C, and 3.5mm Audio Input/Output cables. This ensures compatibility and performance between the KVM switch, monitors, and peripherals - without the need to select and purchase the cables required for those connections.
  • Compatibility
    The 2-port KVM switch is compatible with all operating systems, including Windows, macOS, ChromeOS, and Linux. The KVM works with all hardware platforms including Intel, AMD, and Apple M1/M2. The USB-C host port works with USB-C, USB4, Thunderbolt 3, and Thunderbolt 4 laptops. If the desktop does not have a 4-position 3.5mm port the included 3.5mm Headset Adapter ensures compatibility out of the box.
  • Intuitive Control
    The KVM switch offers two options to switch between hosts - a remote push button or hotkey commands. The remote push button includes a 1.5m cable for optimal placement in the setup. Independent audio switching can be achieved through the software, ensuring uninterrupted audio when switching between host devices.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • MAC Address Pass-Through Utility: Improve network security. • USB Event Monitoring Utility: Track and log connected USB devices. • Wi-Fi Auto Switch Utility: Enable users to quickly access faster network speeds via wired LAN.
StarTech.com 2-Port Hybrid USB-C HDMI Cable KVM Switch, 4K 60Hz, Compact KVM with 6ft/1.8m USB-A/HDMI/Audio & 4ft/1.2m USB-C Integrated Host Cables, Bus Powered - Remote Push Button/Hotkey Switching (C2-H46-UAC-CBL-KVM) - KVM / audio / USB switch - compact - 2 ports
KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
USB powered, remote switch, DisplayPort Alternate mode, 2.1 channel audio support, ABS housing
USB 2.0
9.2 cm x 9.7 cm x 2.4 cm
265 g
Linux, Google Chrome OS, Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
4096 x 2160 @ 60 Hz
USB powered, remote switch, DisplayPort Alternate mode, 2.1 channel audio support, ABS housing, Auto Scan mode
USB 2.0
Status Indicators
Port status
1 x USB input Type C , 2 x audio input mini-jack , 1 x USB 2.0 Type A , 1 x HDMI input , 2 x USB 2.0 output Type A , 1 x audio output mini-jack , 1 x microphone output mini-jack , 1 x HDMI output
4-position to 2 x 3-position 3.5 mm headset adapter
1 x USB-C cable - 1.2 m , 1 x audio cable - 1.2 m , 1 x audio / USB cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x remote control cable - 1.5 m
MTBF
345,059 hours
RoHS, WEEE
9.2 cm
9.7 cm
2.4 cm
265 g
Shipping Width
21 cm
Shipping Depth
16 cm
Shipping Height
6 cm
Shipping Weight
500 g
0 - 90% RH (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
HDG6 StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £16.48
HDG6 StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £20.48
HDG6 StarTech.com 10ft Ultra High Speed HDMI 2.1 In Stock £23.74
HDG6 StarTech.com 2-Port Dual Monitor KVM Switch In Stock £154.39
HDG6 StarTech.com 2-Port Hybrid Cable KVM Switch In Stock £44.04
HDG6 StarTech.com 2-Port USB-C Cable KVM Switch In Stock £86.51
HDG6 StarTech.com 2-Port Dual-Monitor KVM Switch In Stock £198.28
Connectivity: KVM
Ports: 2
