StarTech.com 2 Port High Resolution VGA Video Splitter - 350 MHz
Customer rating: 5.0* (Write a review)
Quicklinx: 3ZGYWS00 Mfr#: ST122PROGB
£24.90 ex VAT
£29.88 inc VAT
This professional grade VGA Video Splitter allows one VGA video source to be displayed on two monitors simultaneously, and features a built-in booster circuit that allows the VGA signal to be extended up to 200 ft.
With support for video bandwidth up to 350MHz, and display resolutions of up to 2048 x 1536 (QXGA), this is the ideal VGA video splitter for presentations, classrooms, tradeshows, or in-store displays where the highest quality video on several monitors is needed.
StarTech.com 2 Port High Resolution VGA Video Splitter - 350 MHz - video splitter - 2 ports
Video splitter - 2 ports
Subtype
VGA
Ports
2 x VGA
AC 230V
22.4 cm x 15.2 cm x 5.2 cm
1.2 kg
P/N: ST121UTPGB
Enclosure Type
Desktop
Subtype
VGA
Ports
2 x VGA
Max Resolution
2048 x 1536 @ 80 Hz
Max Video Bandwidth
350 MHz
Status Indicators
Power, active
2 x VGA HD-15 , 1 x VGA HD-15
External power adapter
AC 230V
FCC Part 15
22.4 cm
15.2 cm
5.2 cm
1.2 kg
StarTech.com UTP VGA/Multisync Video Extender Remote and Local Units
3ZGY StarTech.com DC Power Adapter - 5V, 3A In Stock £12.00
Customer reviews
Write a review for the StarTech.com 2 Port High Resolution VGA Video Splitter - 350 MHz here!
Works well but.....
Reviewed by Chris. Review Posted 17/10/2006
Unit works well but does not include a cable to link from the splitter to the computer.
You will need to have, or order, a male to female 15pSubD (standard VGA monitor cable)
  • Overall 5*
  • Ease of use 3*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
