StarTech.com 2 Port High Resolution USB DVI Dual Link KVM Switch with Audio
Quicklinx: 7P35WS00 Mfr#: SV231DVIUAHR
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 2
£190.18 ex VAT
£228.21 inc VAT
Control two high resolution DVI multimedia computers from a single console. The SV231DVIUAHR 2-Port High Resolution Dual-Link DVI USB KVM Switch provides simple, yet comprehensive control of 2 directly-connected computers, as well as audio switching capability and support for high resolution applications (supports resolutions beyond 1080p: 2560x1600 @ 60Hz, up to 3840 x 2400 at lower refresh rates, and Apple Cinema quality resolutions), offering a superior KVM switching solution that integrates perfectly into demanding imaging, medical, and multimedia environments.
This 2-port DVI USB KVM Switch is compatible with all USB-supported operating systems, and features a built-in USB 2.0 hub that allows you to share additional (up to 2) high speed USB devices between computers.
StarTech.com 2 Port DVI KVM Switch - USB DVI Dual Link - Hot-key & Audio Support - 2560x1600 @ 60Hz KVM Switch - KVM Video Switch (SV231DVIUAHR) - KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub, HDCP compliant
AC 120/230 V
15.9 cm x 10 cm x 4 cm
0.64 kg
3-year warranty
P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA, USBDVI4N1A10, USBDVI4N1A6
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2400 @ 30 Hz
Status Indicators
Port status
2 x USB 2.0 Type B , 2 x DVI-I (dual link) , 2 x audio / headphones mini-jack , 2 x microphone input mini-jack , 1 x DVI-I (dual link) , 2 x USB 2.0 Type A , 1 x audio / headphones mini-jack , 1 x microphone input mini-jack , 2 x keyboard (USB) / mouse (USB) Type A
External power adapter
AC 120/230 V
FCC, RoHS
15.9 cm
10 cm
4 cm
0.64 kg
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
7P35 StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £86.26
7P35 StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £9.54
7P35 StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £8.65
7P35 StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £245.84
7P35 StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £256.34
7P35 StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £183.06
7P35 StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £74.93
7P35 StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £129.00
7P35 StarTech.com 2-port Dual VGA KVM Switch In Stock £67.05
7P35 StarTech.com 4-port Dual VGA KVM Switch In Stock £162.38
7P35 StarTech.com DC Power Adapter - 12V, 2A In Stock £11.96
7P35 StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
Connectivity: KVM
Ports: 2
