Switch between two HDMI video sources on a single display, with support for Ultra HD resolutions. This 2-port HDMI switch lets you share an HDMI 2.0 display or projector with two HDMI 2.0 video sources. The switch features two independent video inputs that can each support 4K resolution at 60Hz, making it the perfect solution for connecting two video sources to a display that has a limited number of HDMI 2.0 ports.
This HDMI switch lets you harness the High Dynamic Range (HDR) capability of your HDMI 2.0 video sources and deliver it to your UHD 4K60 display. Unlike many 4K switches that only support a 30Hz refresh rate, this switch works with HDMI 2.0 displays with output resolutions of up to 3840 x 2160p at 60Hz.
Don't be fooled by a clever spin on old technology. Many HDMI switches support 4K but will only work at a 30Hz refresh rate, or claim support for 60Hz but heavily compress their signal to a lower 4:2:0 chroma subsampling in order to work at inferior bitrates. This 4K 60Hz HDMI switch uses the latest components to offer full support for your HDMI 2.0 equipment, supporting true 4K resolution at 60Hz with 4:4:4 chroma subsampling. Support for HDMI 2.0 devices means this switch can transmit bandwidth up to 18Gbps, making it an ideal video solution for high-resolution computer tasks.
The HDCP 2.2 HDMI switch is backward compatible with 4K 30Hz and 1080p displays, which ensures that it will work with lower resolution displays such as TVs or projectors around your site or in your digital signage application.
This switch ensures effortless operation with automatic switching that detects and selects a newly connected device, perfect for automatically switching to a 4K media player such as a 4K UHD Blu-ray player as soon as it's switched on. In your classroom or office boardroom, the automatic switch makes it easy to share your projector between multiple sources, which encourages on-the-fly collaboration among colleagues.
The HDMI switch also supports manual operation, using the included IR remote control or the built-in front panel toggle switch.
High-resolution support
Experience stunning visual clarity with 4K resolution support, allowing for a breathtaking viewing experience on compatible displays. -
Seamless switching
Effortlessly switch between two HDMI sources using the IR remote control, making it easy to manage your devices without the need to manually swap cables. -
Enhanced audio
With 7.1 channel audio support, this HDMI switcher delivers a rich, immersive audio experience, complementing the high-quality visuals with equally impressive sound. -
Universal compatibility
Designed to work seamlessly with PCs, this switcher ensures a wide range of device compatibility, making it a versatile addition to any setup. -
Durable and compliant
Built to last, this device adheres to strict FCC, HDCP 2.2, and RoHS standards, ensuring reliable performance and compliance with global regulations.
- StarTech.com 2 Port HDMI Switch - 4K 60Hz - Supports HDCP - IR - HDMI Selector - HDMI Multiport Video Switcher - HDMI Switcher (VS221HD20) - video/audio switch - 2 ports
- Video/audio switch - 2 ports
- Subtype
- HDMI
- Ports
- 2 x HDMI
- 4K resolution support, 7.1 channel audio support
- Power
- AC 120/230 V 0.4 A
- 5 cm x 8 cm x 2 cm
- 105 g
- Black
- Localisation
- Australia, New Zealand, North America, United Kingdom, Europe
- 2-year warranty
- Designed For
- P/N: SVA5H2NEUA
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 2 x HDMI
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Status Indicators
- Port status, power
- 2 x HDMI input Type A , 1 x HDMI output Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Electric Current Required
- 0.4 A
- Black
- Included Accessories
- Remote control
- FCC, RoHS, HDCP 2.2
- Localisation
- 5 cm
- 8 cm
- 2 cm
- 105 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 85%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 80 °C
- Humidity Range Storage
- 10 - 85%
- Designed For
- P/N: SVA5H2NEUA
StarTech.com 4-Port 4K HDMI Video Switch | In Stock | £120.78 |
StarTech.com 2-Port 4K HDMI Video Switch | In Stock | £90.59 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £13.18 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £18.49 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £23.48 |
StarTech.com 4-Port HDMI Switch - 4K | In Stock | £39.21 |
StarTech.com 2-Port HDMI Switch - 4K | In Stock | £32.21 |
