StarTech.com 2-Port HDMI Switch - 4K
Quicklinx: CSM1WS00 Mfr#: VS221HD20
Hurry, only 2 left in stock!
£31.28 ex VAT
£37.53 inc VAT
Switch between two HDMI video sources on a single display, with support for Ultra HD resolutions. This 2-port HDMI switch lets you share an HDMI 2.0 display or projector with two HDMI 2.0 video sources. The switch features two independent video inputs that can each support 4K resolution at 60Hz, making it the perfect solution for connecting two video sources to a display that has a limited number of HDMI 2.0 ports.
This HDMI switch lets you harness the High Dynamic Range (HDR) capability of your HDMI 2.0 video sources and deliver it to your UHD 4K60 display. Unlike many 4K switches that only support a 30Hz refresh rate, this switch works with HDMI 2.0 displays with output resolutions of up to 3840 x 2160p at 60Hz.
Don't be fooled by a clever spin on old technology. Many HDMI switches support 4K but will only work at a 30Hz refresh rate, or claim support for 60Hz but heavily compress their signal to a lower 4:2:0 chroma subsampling in order to work at inferior bitrates. This 4K 60Hz HDMI switch uses the latest components to offer full support for your HDMI 2.0 equipment, supporting true 4K resolution at 60Hz with 4:4:4 chroma subsampling. Support for HDMI 2.0 devices means this switch can transmit bandwidth up to 18Gbps, making it an ideal video solution for high-resolution computer tasks.
The HDCP 2.2 HDMI switch is backward compatible with 4K 30Hz and 1080p displays, which ensures that it will work with lower resolution displays such as TVs or projectors around your site or in your digital signage application.
This switch ensures effortless operation with automatic switching that detects and selects a newly connected device, perfect for automatically switching to a 4K media player such as a 4K UHD Blu-ray player as soon as it's switched on. In your classroom or office boardroom, the automatic switch makes it easy to share your projector between multiple sources, which encourages on-the-fly collaboration among colleagues.
The HDMI switch also supports manual operation, using the included IR remote control or the built-in front panel toggle switch.
  • High-resolution support
    Experience stunning visual clarity with 4K resolution support, allowing for a breathtaking viewing experience on compatible displays.
  • Seamless switching
    Effortlessly switch between two HDMI sources using the IR remote control, making it easy to manage your devices without the need to manually swap cables.
  • Enhanced audio
    With 7.1 channel audio support, this HDMI switcher delivers a rich, immersive audio experience, complementing the high-quality visuals with equally impressive sound.
  • Universal compatibility
    Designed to work seamlessly with PCs, this switcher ensures a wide range of device compatibility, making it a versatile addition to any setup.
  • Durable and compliant
    Built to last, this device adheres to strict FCC, HDCP 2.2, and RoHS standards, ensuring reliable performance and compliance with global regulations.
StarTech.com 2 Port HDMI Switch - 4K 60Hz - Supports HDCP - IR - HDMI Selector - HDMI Multiport Video Switcher - HDMI Switcher (VS221HD20) - video/audio switch - 2 ports
Video/audio switch - 2 ports
Subtype
HDMI
Ports
2 x HDMI
4K resolution support, 7.1 channel audio support
AC 120/230 V 0.4 A
5 cm x 8 cm x 2 cm
105 g
Australia, New Zealand, North America, United Kingdom, Europe
P/N: SVA5H2NEUA
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
Port status, power
2 x HDMI input Type A , 1 x HDMI output Type A
External power adapter
AC 120/230 V
Electric Current Required
0.4 A
Remote control
FCC, RoHS, HDCP 2.2
5 cm
8 cm
2 cm
105 g
10 - 85%
Min Storage Temperature
-10 °C
Max Storage Temperature
80 °C
Humidity Range Storage
10 - 85%
P/N: SVA5H2NEUA
CSM1 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
CSM1 StarTech.com 4-Port 4K HDMI Video Switch In Stock £117.90
CSM1 StarTech.com 2-Port 4K HDMI Video Switch In Stock £88.44
CSM1 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
CSM1 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
CSM1 StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.46
CSM1 StarTech.com 4-Port HDMI Switch - 4K In Stock £37.23
CSM1 StarTech.com 2-Port HDMI Switch - 4K In Stock £31.28
