StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz
Quicklinx: FKF8WS00 Mfr#: SV211HDUA4K
Type: KVM
Ports: 2
23 In Stock
£85.35 ex VAT
£102.42 inc VAT
The SV211HDUA4K 2-Port 4K60Hz HDMI Cable KVM Switch with Audio and Remote Switching Control gives you control of two HDMI, USB equipped computers with a single monitor, keyboard, mouse and audio peripheral set.
The Dual HDMI KVM switch supports resolutions up to 4K at 60Hz and can drive one large HDMI display with ease, maximizing viewing space. With support for separate 3.5 mm stereo audio, the KVM switch delivers full audio compatibility across connected computers.
While supporting most PC operating systems, this HDMI KVM switch is OS independent which means it works with Mac computers (an adapter may be required) and any other laptops, notebooks, and tablets.
The switch features a remote push-button on a 1.5 meter (4ft) integrated cable that can be placed in an easily accessible location, as well as keyboard hot-keys, and PC or Mac compatible software for switching between systems.
StarTech.com offers a wide selection of high-quality KVM switches and KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice and monitors.
  • High-resolution support
    Experience visuals with support for maximum video resolution of 3840 x 2160, ensuring clear image quality for demanding applications.
  • Versatile connectivity options
    The KVM switch includes multiple input and output types, including HDMI, USB, and audio options, making it adaptable for various devices.
  • Efficient power management
    The USB-powered design eliminates the need for an external power adapter, simplifying setup while maintaining energy efficiency.
  • Robust environmental tolerance
    Designed to operate in a range of temperatures from 0°C to 40°C and humidity levels up to 90%, making it suitable for diverse operational environments.
  • User-friendly operation
    Features a remote switch function that allows for control of multiple computers with one set of peripherals, providing convenience in multitasking.
StarTech.com 2 Port HDMI KVM Switch, 4K 60Hz, Compact Dual Port UHD/Ultra HD USB Desktop KVM Switch with Integrated 4ft Cables & Audio, Bus Powered & Remote Switching, MacBook ThinkPad - 4K KVM Switch w/ Audio (SV211HDUA4K) - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
USB powered, remote switch, 4K resolution support
8.218 cm x 9.7 cm x 0.91 cm
350 g
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
Status
1 x HDMI output , 2 x HDMI input , 2 x USB 2.0 input Type A , 2 x USB 2.0 output Type A , 2 x microphone input mini-jack , 1 x microphone output mini-jack , 2 x audio input mini-jack , 1 x audio output mini-jack
2 x keyboard / mouse / video / audio cable , 1 x remote control cable - 1.5 m
MTBF
1,012,884 hours
FCC, RoHS, REACH
8.218 cm
9.7 cm
0.91 cm
350 g
Shipping Width
6 cm
Shipping Depth
21 cm
Shipping Height
16 cm
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
FKF8 StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £4.89
FKF8 StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £5.37
FKF8 StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £6.20
FKF8 StarTech.com 1m Slim 3.5mm Stereo Extension Audio Cable - M/F In Stock £2.65
FKF8 StarTech.com 1m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £5.53
FKF8 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.71
FKF8 StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.11
FKF8 StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz In Stock £85.35
FKF8 StarTech.com 2 Port USB C KVM Switch In Stock £77.13
FKF8 StarTech.com 2 Port Dual Monitor HDMI KVM Switch In Stock £313.02
FKF8 StarTech.com 2 Port HDMI KVM Switch In Stock £240.42
FKF8 StarTech.com 4 Port HDMI KVM Switch In Stock £323.66
FKF8 StarTech.com 2 Port Hybrid USB-C KVM Switch In Stock £32.88
Type: KVM
Ports: 2
