StarTech.com 2 Port Gigabit PoE+ Extender
Quicklinx: CGW0WS00 Mfr#: POEEXT2GAT
Extend two Power over Ethernet devices by 100 meters, or daisy chain up to four extenders for longer distance. This 2-port Gigabit PoE+ extender spans your Power over Ethernet (PoE) devices over longer distances, letting you double the 100 m limitation of a traditional PoE infrastructure.
Now you can connect two Gigabit PoE devices up to a maximum of 200 m away, so it's easy to install a remote IP camera or access point where you need it. Plus, you can daisy-chain the extender for more scalability.
Need more distance? This convenient two-port PoE+ repeater maximizes range and flexibility by extending your PoE connections by an extra 100 m (330 ft.), while providing 23-watt power output to two compatible devices. (The power output is shared between each PoE output port).
Simply connect the extender to your power sourcing equipment (PSE) and your PoE-powered devices (PD) and you're all set. The extender is compliant with the 802.3at/af standard, so it will work with existing PSE, such as a StarTech.com PoE+ injector (POEINJ1G) or PoE+ switch (IES81000POE).
Still need more distance? If an extra 100 m isn't enough, this full-featured PoE extender offers daisy-chain capability.
You can easily connect four extenders together, letting you install two PoE+ PDs up to 500 m (1640 ft.) away. It's perfect for business, education, and retail environments. (Output wattage is dependent on the number of daisy-chained extenders used, and the number of connected PoE devices).
Get up and running quickly. This 2-port Gigabit PoE+ extender can be positioned right where you need it, with a wall-mountable design that requires no external power adapter.
With its rugged metal housing and built-in ESD and surge protection, the PoE+ extender gives you reliable performance with little worry of downtime or failure.
StarTech.com 2 Port Gigabit PoE+ Extender 802.3at & 802.3af - 100m (330ft) - Power over Ethernet Extender - PoE Repeater Network Extender (POEEXT2GAT) - network extender - 10Mb LAN, 100Mb LAN, 1GbE
Network extender - RJ-45 / 2 x RJ-45
Ports Qty
2
External
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Max Transfer Distance
100 m
Power Over Ethernet (PoE)
PoE+
7.2 cm x 14 cm x 2.7 cm
235 g
P/N: ST12MHDLANU
Network extender
External
Ports Qty
2
Wired
Cabling Type
100 m
Status Indicators
PoE, link/activity
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, 4KV ESD Protector, 4KV Surge protection
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ input) - RJ-45 , 2 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ output) - RJ-45
MTBF
50,000 hours
EN 61000-4-2, EN 61000-4-5, FCC, RoHS
PoE+
3 Watt
7.2 cm
14 cm
2.7 cm
235 g
50 °C
5 - 95% (non-condensing)
P/N: ST12MHDLANU
CGW0 StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.89
CGW0 StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable In Stock £211.09
CGW0 StarTech.com 4 Port Gigabit PoE+ Injector In Stock £119.31
CGW0 StarTech.com Gigabit PoE+ Extender - 100m In Stock £97.83
