StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention
Quicklinx: 7NZ4WS00 Mfr#: ICUSB2322F
Type: Serial adapter
Compatibility: PC, Mac
Interface: USB
£48.01 ex VAT
£57.61 inc VAT
The ICUSB2322F 2-Port USB to Serial RS232 Adapter Cable with FTDI chipset and COM Retention converts an available USB 1.1 or 2.0 port into 2 RS232 serial DB9 ports to connect, monitor and control your serial devices.
This compact adapter features COM retention, allowing the same COM port values to automatically be re-assigned to the port if the cable is disconnected and re-connected to the host computer, or if the system is rebooted. Unlike most USB-serial adapters, this one uses the FTDI chipset, which supports additional customization, advanced features, and compatibility not necessarily offered by other solutions.
This USB-serial adapter is compatible with a broad list of Operating Systems, including Windows, Windows CE, Mac OS and Linux, making this product the perfect solution for integrating into mixed environments.
  • Effortless connectivity
    The USB to Serial Adapter from StarTech.com ensures seamless connectivity between your USB-A devices and serial peripherals. With two RS-232 ports, it offers a reliable solution for connecting to a wide range of serial devices.
  • Durable design
    Designed with an integrated 1.8 cm USB cable, this adapter is built for durability and a straightforward setup. Its compliance with FCC and RoHS standards further ensures quality and safety.
  • Versatile compatibility
    This adapter's broad compatibility with both Mac and PC systems, alongside its COM port retention feature, provides a versatile solution for various operational environments, ensuring your serial devices are always connected.
  • Optimal operating conditions
    With an operating humidity range of 5 - 95% and temperature tolerance from 0 °C to 55 °C, the adapter is engineered to perform reliably in diverse working conditions.
  • Convenient features
    Featuring USB-powered operation and easy-to-see power status indicators, this serial adapter simplifies installation and monitoring, making it a user-friendly solution for any setup.
StarTech.com USB to Serial Adapter - 2 Port - COM Port Retention - FTDI - USB to RS232 Adapter Cable - USB to Serial Converter (ICUSB2322F) - serial adapter - USB - RS-232 x 2
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232 x 2
300 g
RS-232
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
Serial adapter
External
USB
Ports
RS-232 x 2
Wired
RS-232
Status Indicators
USB powered
2 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB - 4 pin USB Type A
1 x USB cable (integrated) - 1.8 cm
Mounting Kit
Included
FCC, RoHS
300 g
55 °C
5 - 95%
7NZ4 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £22.01
7NZ4 StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £33.15
7NZ4 StarTech.com 4 Port Black USB 2.0 Hub In Stock £19.43
7NZ4 StarTech.com 7 Port Black USB 2.0 Hub In Stock £23.67
7NZ4 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.62
7NZ4 StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £48.01
7NZ4 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £98.51
7NZ4 StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips In Stock £55.58
7NZ4 StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £25.80
7NZ4 StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £92.54
7NZ4 StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £154.54
7NZ4 StarTech.com USB to RS232 Serial Adapter In Stock £16.69
7NZ4 StarTech.com 4 Port USB to Serial Hub In Stock £82.40
7NZ4 StarTech.com UCB C to Serial Adapter In Stock £17.40
7NZ4 StarTech.com 8-Port USB to Serial Adapter In Stock £355.84
Compatibility: PC
Compatibility: Mac
Interface: USB
