The ICUSB2322F 2-Port USB to Serial RS232 Adapter Cable with FTDI chipset and COM Retention converts an available USB 1.1 or 2.0 port into 2 RS232 serial DB9 ports to connect, monitor and control your serial devices.
This compact adapter features COM retention, allowing the same COM port values to automatically be re-assigned to the port if the cable is disconnected and re-connected to the host computer, or if the system is rebooted. Unlike most USB-serial adapters, this one uses the FTDI chipset, which supports additional customization, advanced features, and compatibility not necessarily offered by other solutions.
This USB-serial adapter is compatible with a broad list of Operating Systems, including Windows, Windows CE, Mac OS and Linux, making this product the perfect solution for integrating into mixed environments.
- StarTech.com USB to Serial Adapter - 2 Port - COM Port Retention - FTDI - USB to RS232 Adapter Cable - USB to Serial Converter (ICUSB2322F) - serial adapter - USB - RS-232 x 2
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232 x 2
- 300 g
- Data Link Protocol
- RS-232
- Black
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- RS-232
- Status Indicators
- Power
- USB powered
- 2 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
- 1 x USB - 4 pin USB Type A
- Cables Included
- 1 x USB cable (integrated) - 1.8 cm
- Mounting Kit
- Included
- FCC, RoHS
- Black
- OS Required
- 300 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.54 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £33.25 |
StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £20.37 |
StarTech.com 7 Port Black USB 2.0 Hub | In Stock | £23.41 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.11 |
StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £48.66 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation | In Stock | £108.11 |
StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips | In Stock | £60.21 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £26.05 |
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £102.21 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £174.29 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.55 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £79.27 |
StarTech.com UCB C to Serial Adapter | In Stock | £18.31 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £244.59 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £388.76 |
