This 2 Port ExpressCard FireWire Adapter Card adds two 1394b FireWire ports to a laptop computer, providing a cost-effective way to add IEEE 1394A and IEEE 1394B FireWire devices even if the laptop doesn't have a built-in FireWire 400 or FireWire 800 port. Simply insert the IEEE 1394B FireWire 800 card (EC1394B2) into an ExpressCard slot, and you'll be able to connect a broad range of FireWire devices to your laptop, while relying on data transfer speeds of up to 800Mbps. Plus, the card is backward compatible with 1394a devices, so you can connect both FireWire 400 and 800 devices to the notebook, using the same adapter.
- StarTech.com 2 Port ExpressCard 1394b FireWire Laptop Adapter Card - Texas Instruments FireWire Card - ExpressCard FireWire 800 (EC1394B2) - FireWire adapter - ExpressCard - FireWire 800 x 2
- FireWire adapter
- Form Factor
- Plug-in module
- Interface (Bus) Type
- ExpressCard/34
- Ports
- FireWire 800 x 2
- 3.4 cm x 12 cm x 2 cm
- 30 g
- Data Link Protocol
- FireWire 800
- Data Transfer Rate
- 800 Mbps
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP, Windows 10 (32/64 bits)
- Limited lifetime warranty
- FireWire adapter
- Form Factor
- Plug-in module
- ExpressCard/34
- Ports
- FireWire 800 x 2
- Connectivity Technology
- Wired
- IEEE 1394b (FireWire 800)
- 800 Mbps
- 2 x FireWire 800 - 9 pin FireWire 800
- Compatible Slots
- 1 x ExpressCard/34
- C-Tick, FCC
- OS Required
- 3.4 cm
- 12 cm
- 2 cm
- 30 g
- Limited warranty - lifetime
StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter | In Stock | £47.64 |
StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter | In Stock | £26.07 |
StarTech.com 10 ft 1394b Firewire 800 Cable 9-9 M/M | In Stock | £11.47 |
