The ST122DVIA DVI splitter lets you share one DVI video and audio source on two displays and acts as a signal amplifier that allows you to locate your DVI monitors up to 33ft (10 m) away from your computer or DVI signal source.
With support for high definition resolutions up to 1080p (HDTV)/1920x1200 (PC), the DVI splitter delivers a simple and convenient DVI video solution that suits virtually any application or operating environment (classroom, healthcare, professional A/V, control centers, retail POS environments).
The DVI video splitter/distribution amplifier is easy to install, providing you with flawless digital video that will help you get the most from your DVI-enabled monitors, projectors, or plasma screens. The DVI splitter/signal distribution amplifier is designed to provide dependable performance.
- StarTech.com 2 Port DVI Video Splitter with Audio - DVI Splitter with Audio - 2 Port DVI Splitter - DVI Video Splitter (ST122DVIA) - video/audio splitter - 2 ports
- Video/audio splitter - 2 ports
- Subtype
- DVI / audio
- Ports
- 2 x DVI + 2 x audio
- HDCP 1.1, DVI 1.0
- 8.5 cm x 18.1 cm x 2 cm
- 0.6 kg
- Black
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- DVI / audio
- Ports
- Max Resolution
- 1920 x 1200 @ 60 Hz
- HDCP 1.1, DVI 1.0
- 2 x DVI-I , 2 x audio mini-jack , 1 x DVI-I , 1 x audio mini-jack
- Power Device
- External power adapter
- Black
- FCC, RoHS
- 8.5 cm
- 18.1 cm
- 2 cm
- 0.6 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.49 |
StarTech.com 2 Port DVI Video Splitter with Audio | In Stock | £105.64 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.94 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.83 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.75 |
StarTech.com 1 ft DVI-D to 2x DVI-D Digital Video Splitter Cable - M/F | In Stock | £13.55 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £5.00 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
