StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub
Quicklinx: 6PG7WS00 Mfr#: SV231DDVDUA
Type: KVM / audio / USB switch
Ports: 2
Connectivity: KVM
£135.05 ex VAT
£162.06 inc VAT
Share a keyboard and mouse as well as 1 VGA and 1 DVI displays/monitors between 2 multimedia computers. The SV231DDVDUA 2-port Dual Monitor KVM Switch (DVI+VGA) offers a complete multimedia switching solution, letting users control two Dual Display computers using a single USB mouse and keyboard peripheral set.
With support for high-resolution video interfaces, this dual view KVM switch provides one VGA (analog) and one DVI-I port per computer connection, as well as audio switching capability between connected computers.
Delivering versatility for virtually any application, the DVI/VGA KVM switch features an integrated 2-port USB hub that allows connected USB 2.0 peripherals to be shared between connected computers, eliminating the need to purchase duplicate peripherals.
Suitable for any workspace, the dual monitor KVM switch offers a compact desktop KVM design and features a rugged metal chassis that helps ensure durable performance.
Note: If you're connecting a digital display to the DVI console port, it is recommended you use a DVI-D digital cable. However, if you're connecting an analog display (adapter required), it is recommended you use a DVI-I or a DVI-A cable.
StarTech.com 2 Port KVM Switch - DVI and VGA w/ Audio and USB 2.0 Hub - Dual Monitor / Display / Screen KVM Switch - DVI VGA (SV231DDVDUA) - KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub, HDCP compliant
16 cm x 10 cm x 5.7 cm
0.75 kg
3-year warranty
P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA, USBDVI4N1A10, USBDVI4N1A6, USBVGA4N1A10, USBVGA4N1A6
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
2 x VGA HD-15 , 2 x DVI-I , 2 x keyboard (USB) / mouse (USB) Type B , 2 x microphone mini-jack , 2 x speakers mini-jack , 1 x VGA HD-15 , 1 x DVI-I , 1 x microphone mini-jack , 1 x speakers mini-jack , 2 x keyboard (USB) / mouse (USB) Type A , 2 x USB 2.0 Type A
External power adapter
FCC, RoHS
16 cm
10 cm
5.7 cm
0.75 kg
Limited warranty - 3 years
6PG7 StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £13.08
6PG7 StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £7.52
6PG7 StarTech.com 10ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £19.51
6PG7 StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £28.56
6PG7 StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £258.35
6PG7 StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £201.27
6PG7 StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £135.05
6PG7 StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £1.36
6PG7 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.54
6PG7 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.01
6PG7 StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.16
6PG7 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.56
6PG7 StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £12.03
6PG7 StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £117.16
6PG7 StarTech.com 6 ft 4-in-1 USB VGA KVM Switch Cable with Audio and Microphone In Stock £7.02
6PG7 StarTech.com 4 Port USB DVI KVM Switch with DDM Fast Switching Technology and Cables In Stock £220.80
6PG7 StarTech.com 2-port Dual VGA KVM Switch In Stock £134.52
6PG7 StarTech.com DC Power Adapter - 12V, 2A In Stock £13.33
6PG7 StarTech.com DC Power Adapter - 12V, 5A In Stock £33.16
Ports: 2
Connectivity: KVM
Stock Status: In stock
