StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub
Quicklinx: 7P34WS00 Mfr#: SV231DVIUA
Type: KVM / audio / USB switch
Ports: 2
Connectivity: KVM
Hurry, only 2 left in stock!
£128.51 ex VAT
£154.21 inc VAT
Share keyboard, mouse, speakers and a DVI display between two multimedia computers. The SV231DVIUA 2-Port DVI USB KVM Switch lets you control two USB-enabled, DVI-capable computers from a single monitor and peripheral set (keyboard, mouse and speakers), and two additional USB peripherals connected through the built-in USB hub ports.
Featuring convenient hot-key and front panel push-button switching, and high-resolution support (up to 1920x1200), the DVI KVM Switch is perfect for controlling high-performance systems. Ideal for multimedia applications, this KVM switch supports audio and microphone switching either independently, or simultaneously when switching between computers for KVM control.
The DVI USB KVM also features an integrated USB 2.0 hub, which lets you share USB peripherals point as if they were connected directly to the slave computers.
StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub (SV231DVIUA) - KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub, HDCP compliant
AC 120/230 V
16 cm x 10 cm x 4 cm
1.2 kg
3-year warranty
P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA, USBDVI4N1A10, USBDVI4N1A6
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200 @ 70 Hz
Status Indicators
Port status
2 x USB 2.0 Type B , 2 x DVI-I , 2 x audio / headphones mini-jack , 2 x microphone input mini-jack , 1 x DVI-I , 2 x USB 2.0 Type A , 1 x audio / headphones mini-jack , 1 x microphone input mini-jack , 2 x keyboard (USB) / mouse (USB) Type A
External power adapter
AC 120/230 V
FCC, RoHS
16 cm
10 cm
4 cm
1.2 kg
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
7P34 StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £239.06
7P34 StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £249.28
7P34 StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £115.45
7P34 StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £131.32
7P34 StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £128.51
7P34 StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
7P34 StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
Ports: 2
Connectivity: KVM
