StarTech.com 2-Port Dual-Monitor KVM Switch
Quicklinx: HHXDWS00 Mfr#: P2DD46A2-KVM-SWITCH
£314.68 ex VAT
£377.61 inc VAT
This Dual-Monitor KVM Switch enables users to switch between two desktops that are USB-A and DisplayPort enabled. It allows for sharing of dual-4K 60Hz DisplayPort monitors, a keyboard and mouse, and two USB 5Gbps devices.
  • Fast Switching with USB Emulation
    USB Emulation technology enables faster switching of a keyboard, video, and mouse compared to traditional KVMs. USB Emulation also ensures compatibility with combination keyboards/mice as well as keyboards featuring additional function keys.
  • Dual-4K 60Hz Displays & USB 5Gbps Hub Ports
    This TAA-Compliant KVM Switch supports dual-4K 60Hz DisplayPort monitors, making it ideal for working with high-resolution graphics or video. Additionally, it offers two USB 3.2 Gen 1 (5Gbps) Hub Ports for fast data transfer, and two USB 2.0 HID Ports for the keyboard and mouse. 8kV air and 6kV contact Electrostatic Discharge (ESD) protection.
  • Customizable Switching
    This Universal KVM Switch provides various switching options, including hotkey or push-button switching. Hotkeys allow for independent switching of USB/Video and Audio, enabling audio playback from one computer while controlling the other. An audible buzzer confirms hotkey input, and LEDs provide a visual status of the selected host.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • MAC Address Pass-Through Utility: Improve network security. • USB Event Monitoring Utility: Track and log connected USB devices. • Wi-Fi Auto Switch Utility: Enable users to quickly access faster network speeds via wired LAN.
StarTech.com 2-Port Dual-Monitor DisplayPort KVM Switch, 4K 60Hz, 2x USB 5Gbps Hub Ports, 2x USB 2.0 HID Ports, Hotkey and Push-Button Switching, TAA Compliant - ESD Level 3 Protection (P2DD46A2-KVM-SWITCH) - KVM / audio / USB switch - 2 ports - TAA Compliant
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
8KV ESD Protector (air-gap discharge), 6KV ESD Protector (contact discharge), steel housing, 2.1 channel audio support, hotkeys
USB 2.0, USB 3.2 Gen 1
AC 100-240 V 1 A
16.3 cm x 10 cm x 6.6 cm
800 g
Japan, New Zealand, North America, United Kingdom, Europe
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
PC, hub
2 x DisplayPort output console , 2 x USB 2.0 Type A , 2 x USB 3.2 Gen 1 Type A , 1 x headphones mini-jack console , 1 x microphone mini-jack console , 4 x DisplayPort input , 2 x USB 3.2 Gen 1 Type B , 2 x headphones mini-jack , 2 x microphone mini-jack
External power adapter
Power Provided
DC 12 V - 3 A
AC 100-240 V
Electric Current Required
1 A
MTBF
173,052 hours
FCC Part 15, RoHS, WEEE, DisplayPort 1.2
TAA Compliant
16.3 cm
10 cm
6.6 cm
800 g
Shipping Width
27 cm
Shipping Depth
16 cm
Shipping Height
19.2 cm
Shipping Weight
1.3 kg
0 - 90% RH (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
HHXD StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.07
HHXD StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £14.23
HHXD StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £15.38
HHXD StarTech.com 10ft DisplayPort 1.4 8K 60Hz In Stock £30.05
HHXD StarTech.com 16ft DisplayPort 1.4 8K 60Hz In Stock £35.35
HHXD StarTech.com 4-Port Dual-Monitor KVM Switch In Stock £661.51
HHXD StarTech.com Dual-Monitor DP 1.4 KVM Switch In Stock £410.36
HHXD StarTech.com 2-Port DisplayPort + HDMI KVM In Stock £304.28
