StarTech.com 2-Port Dual-Monitor KVM Switch
Quicklinx: HDG5WS00 Mfr#: C2-DH46-UA2-CBL-KVM
Type: KVM / audio / USB switch
Ports: 2
Connectivity: KVM
£207.31 ex VAT
£248.77 inc VAT
This Dual-Monitor KVM Switch enables users to switch between two USB-A and HDMI-enabled desktops, sharing dual-4K 60Hz HDMI monitors, a keyboard and mouse, and audio input/output devices.
  • Hassle-Free Setup
    The KVM switch is bus powered and features built-in dual-HDMI, USB-A, and 3.5mm Audio Input/Output cables. This ensures compatibility and performance between the KVM switch, monitors, and peripherals - without the need to select and purchase the cables required for those connections.
  • Compatibility
    The 2-port KVM switch is compatible with all operating systems, including Windows, macOS, ChromeOS, and Linux. The KVM works with all hardware platforms including Intel, AMD, and Apple M1/M2.
  • Intuitive Control
    The KVM switch features two options to switch between hosts - a remote push button and hotkey commands, using the downloadable software. The remote push button includes a 1.5m cable for optimal placement in the setup. Independent audio switching can be achieved through the software, utilizing keyboard shortcuts (i.e., hotkeys), ensuring uninterrupted audio when switching between host devices.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • MAC Address Pass-Through Utility: Improve network security. • USB Event Monitoring Utility: Track and log connected USB devices. • Wi-Fi Auto Switch Utility: Enable users to quickly access faster network speeds via wired LAN.
StarTech.com 2-Port Dual-Monitor HDMI Cable KVM Switch, 4K 60Hz, Compact KVM with 5ft/1.5m USB-A/HDMI/Audio Integrated Cables, Bus Powered - Remote Push Button/Hotkey Switching (C2-DH46-UA2-CBL-KVM) - KVM / audio / USB switch - compact - 2 ports
KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
USB powered, remote switch, 2.1 channel audio support, ABS housing
USB 2.0
12.7 cm x 8.3 cm x 2.6 cm
600 g
Linux, Google Chrome OS, Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
4096 x 2160 @ 60 Hz
USB powered, remote switch, 2.1 channel audio support, ABS housing, Auto Scan mode
USB 2.0
Status Indicators
Port status, audio
4 x HDMI input , 2 x audio input mini-jack , 2 x microphone input mini-jack , 2 x USB 2.0 input Type A , 2 x HDMI output , 1 x microphone output mini-jack , 1 x audio output mini-jack , 2 x USB 2.0 output Type A
4 x HDMI cable - 1.5 m , 2 x audio / USB cable - 1.5 m , 1 x remote control cable - 1.5 m
MTBF
26,928 hours
RoHS, WEEE
12.7 cm
8.3 cm
2.6 cm
600 g
Shipping Width
21 cm
Shipping Depth
16 cm
Shipping Height
10 cm
Shipping Weight
800 g
0 - 90% RH (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
HDG5 StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £16.49
HDG5 StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £20.48
HDG5 StarTech.com 10ft Ultra High Speed HDMI 2.1 In Stock £23.74
HDG5 StarTech.com 12ft Ultra High Speed HDMI 2.1 In Stock £33.33
HDG5 StarTech.com 2-Port Dual Monitor KVM Switch In Stock £161.16
HDG5 StarTech.com 2-Port Hybrid Cable KVM Switch In Stock £104.47
HDG5 StarTech.com 2-Port USB-C Cable KVM Switch In Stock £90.34
HDG5 StarTech.com 2-Port Hybrid Cable KVM Switch In Stock £94.61
Ports: 2
Connectivity: KVM
