This Dual-Monitor KVM Switch enables users to switch between two USB-A and HDMI-enabled desktops, sharing dual-4K 60Hz HDMI monitors, a keyboard and mouse, and audio input/output devices.
Hassle-Free Setup
The KVM switch is bus powered and features built-in dual-HDMI, USB-A, and 3.5mm Audio Input/Output cables. This ensures compatibility and performance between the KVM switch, monitors, and peripherals - without the need to select and purchase the cables required for those connections. -
Compatibility
The 2-port KVM switch is compatible with all operating systems, including Windows, macOS, ChromeOS, and Linux. The KVM works with all hardware platforms including Intel, AMD, and Apple M1/M2. -
Intuitive Control
The KVM switch features two options to switch between hosts - a remote push button and hotkey commands, using the downloadable software. The remote push button includes a 1.5m cable for optimal placement in the setup. Independent audio switching can be achieved through the software, utilizing keyboard shortcuts (i.e., hotkeys), ensuring uninterrupted audio when switching between host devices. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • MAC Address Pass-Through Utility: Improve network security. • USB Event Monitoring Utility: Track and log connected USB devices. • Wi-Fi Auto Switch Utility: Enable users to quickly access faster network speeds via wired LAN.
- StarTech.com 2-Port Dual-Monitor HDMI Cable KVM Switch, 4K 60Hz, Compact KVM with 5ft/1.5m USB-A/HDMI/Audio Integrated Cables, Bus Powered - Remote Push Button/Hotkey Switching (C2-DH46-UA2-CBL-KVM) - KVM / audio / USB switch - compact - 2 ports
- KVM / audio / USB switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- USB powered, remote switch, 2.1 channel audio support, ABS housing
- USB 2.0
- 12.7 cm x 8.3 cm x 2.6 cm
- 600 g
- Black
- System Requirements
- Linux, Google Chrome OS, Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 4096 x 2160 @ 60 Hz
- USB powered, remote switch, 2.1 channel audio support, ABS housing, Auto Scan mode
- USB 2.0
- Status Indicators
- Port status, audio
- 4 x HDMI input , 2 x audio input mini-jack , 2 x microphone input mini-jack , 2 x USB 2.0 input Type A , 2 x HDMI output , 1 x microphone output mini-jack , 1 x audio output mini-jack , 2 x USB 2.0 output Type A
- Black
- Cables Included
- 4 x HDMI cable - 1.5 m , 2 x audio / USB cable - 1.5 m , 1 x remote control cable - 1.5 m
- MTBF
- 26,928 hours
- RoHS, WEEE
- OS Required
- 12.7 cm
- 8.3 cm
- 2.6 cm
- 600 g
- Shipping Width
- 21 cm
- Shipping Depth
- 16 cm
- Shipping Height
- 10 cm
- Shipping Weight
- 800 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% RH (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £16.45 |
StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £20.48 |
StarTech.com 10ft Ultra High Speed HDMI 2.1 | In Stock | £23.74 |
StarTech.com 12ft Ultra High Speed HDMI 2.1 | In Stock | £33.33 |
StarTech.com 2-Port Dual Monitor KVM Switch | In Stock | £163.98 |
StarTech.com 2-Port Hybrid Cable KVM Switch | In Stock | £105.69 |
StarTech.com 2-Port USB-C Cable KVM Switch | In Stock | £91.58 |
StarTech.com 2-Port Hybrid Cable KVM Switch | In Stock | £96.16 |
