This Dual-Monitor KVM Switch enables users to switch between two desktops that are USB-A and DisplayPort enabled. It allows for sharing of dual-4K 60Hz DisplayPort monitors, a keyboard and mouse, and two USB 5Gbps devices.
Fast Switching with USB Emulation
USB Emulation technology enables faster switching of a keyboard, video, and mouse compared to traditional KVMs. USB Emulation also ensures compatibility with combination keyboards/mice as well as keyboards featuring additional function keys. -
Dual-4K 60Hz Displays & USB 5Gbps Hub Ports
This TAA-Compliant KVM Switch supports dual-4K 60Hz DisplayPort monitors, making it ideal for working with high-resolution graphics or video. Additionally, it offers two USB 3.2 Gen 1 (5Gbps) Hub Ports for fast data transfer, and two USB 2.0 HID Ports for the keyboard and mouse. 8kV air and 6kV contact Electrostatic Discharge (ESD) protection. -
Customizable Switching
This Universal KVM Switch provides various switching options, including hotkey or push-button switching. Hotkeys allow for independent switching of USB/Video and Audio, enabling audio playback from one computer while controlling the other. An audible buzzer confirms hotkey input, and LEDs provide a visual status of the selected host. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • MAC Address Pass-Through Utility: Improve network security. • USB Event Monitoring Utility: Track and log connected USB devices. • Wi-Fi Auto Switch Utility: Enable users to quickly access faster network speeds via wired LAN.
- StarTech.com 2-Port Dual-Monitor DisplayPort KVM Switch, 4K 60Hz, 2x USB 5Gbps Hub Ports, 2x USB 2.0 HID Ports, Hotkey and Push-Button Switching, TAA Compliant - ESD Level 3 Protection (P2DD46A2-KVM-SWITCH) - KVM / audio / USB switch - 2 ports - TAA Compliant
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- 8KV ESD Protector (air-gap discharge), 6KV ESD Protector (contact discharge), steel housing, 2.1 channel audio support, hotkeys
- USB 2.0, USB 3.2 Gen 1
- Power
- AC 100-240 V 1 A
- 16.3 cm x 10 cm x 6.6 cm
- 800 g
- Black
- Localisation
- Japan, New Zealand, North America, United Kingdom, Europe
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Status Indicators
- PC, hub
- 2 x DisplayPort output console , 2 x USB 2.0 Type A , 2 x USB 3.2 Gen 1 Type A , 1 x headphones mini-jack console , 1 x microphone mini-jack console , 4 x DisplayPort input , 2 x USB 3.2 Gen 1 Type B , 2 x headphones mini-jack , 2 x microphone mini-jack
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 3 A
- Voltage Required
- AC 100-240 V
- Electric Current Required
- 1 A
- Black
- MTBF
- 173,052 hours
- FCC Part 15, RoHS, WEEE, DisplayPort 1.2
- TAA Compliant
- Localisation
- 16.3 cm
- 10 cm
- 6.6 cm
- 800 g
- Shipping Width
- 27 cm
- Shipping Depth
- 16 cm
- Shipping Height
- 19.2 cm
- Shipping Weight
- 1.3 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% RH (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.41 |
StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £13.82 |
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £15.15 |
StarTech.com 10ft DisplayPort 1.4 8K 60Hz | In Stock | £20.57 |
StarTech.com 16ft DisplayPort 1.4 8K 60Hz | In Stock | £35.05 |
StarTech.com 4-Port Dual-Monitor KVM Switch | In Stock | £627.58 |
StarTech.com Dual-Monitor DP 1.4 KVM Switch | In Stock | £389.32 |
StarTech.com 2-Port DisplayPort + HDMI KVM | In Stock | £288.68 |
