KVM with USB - TAA Compliant - USB 3.0 Hub - HDMI 2.0 - Digital & Analog Audio
This 2-port KVM switch combines 4K (60Hz) digital display capabilities with control of two connected computers.
4K 60Hz Picture and Full Audio Support
The HDMI KVM switch supports resolutions up to 4K at 60Hz. It drives two large monitors at the full 4K resolution. Includes EDID and HDCP signal emulation so monitors always remain synced for faster switching times, and desktop settings are maintained to avoid disrupting your workflow.
With support for digital audio (with supporting displays and sources) and separate 3.5 mm stereo audio, the HDMI 2.0 KVM switch delivers full audio compatibility.
Integrated USB Hub
The integrated USB 3.0 hub shares two peripherals (in addition to keyboard and mouse) among attached computers as if they were directly connected to your host computer, eliminating the cost of duplicate devices such as printers and scanners.
Windows, Mac & Linux Compatible
While supporting Windows, this HDMI KVM switch is also compatible with Mac and Linux operating systems.
Easy to Operate
The front-panel pushbuttons make it easy to switch between systems and activate the auto-scan feature. The hotkey functionality makes accessing each system quickly, while a buzzer sound confirms the switch.
StarTech.com offers a wide selection of high-quality KVM switches and KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice, and monitors.
This 2-port HDMI KVM switch is backed by a 2-year warranty and free lifetime technical support.
The HDMI KVM switch supports resolutions up to 4K at 60Hz. It drives two large monitors at the full 4K resolution. Includes EDID and HDCP signal emulation so monitors always remain synced for faster switching times, and desktop settings are maintained to avoid disrupting your workflow. With support for digital audio (with supporting displays and sources) and separate 3.5 mm stereo audio, the HDMI 2.0 KVM switch delivers full audio compatibility. -
Integrated USB Hub
- StarTech.com 2 Port Dual Monitor HDMI KVM Switch, 4K 60Hz Ultra HD HDR, Desktop 4K HDMI 2.0 KVM Switch with 2 Port USB 3.0 Hub (5Gbps) & 4x USB 2.0 HID Port, Audio, Hotkey Switching, TAA - KVM with Fast Switching - KVM / audio switch - 2 ports - TAA Compliant
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- 7.1 channel audio support, HDR10 support
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 100-240 V
- 10 cm x 16 cm x 5.8 cm
- Black
- Localisation
- Japan, New Zealand, North America, United Kingdom, Europe
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Status Indicators
- Status
- 2 x HDMI output , 4 x HDMI input , 2 x USB 3.0 output Type A , 2 x USB 3.0 input Type B , 4 x USB 1.1 Type A , 2 x audio input mini-jack , 1 x audio output mini-jack , 1 x mini-USB Type B
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 3 A
- Voltage Required
- AC 100-240 V
- 36 Watt
- Black
- Included Accessories
- 4 rubber feet
- MTBF
- 156,000 hours
- FCC, RoHS, EDID compatible, HDCP 2.2
- TAA Compliant
- Localisation
- 10 cm
- 16 cm
- 5.8 cm
- Shipping Width
- 23.8 cm
- Shipping Depth
- 18.9 cm
- Shipping Height
- 9.1 cm
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £10.03 |
StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £11.41 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £9.21 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.83 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.29 |
StarTech.com 2m 6ft USB 3.0 C to B Cable | In Stock | £15.29 |
StarTech.com 3m USB 2.0 C to B Cable | In Stock | £20.31 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £17.73 |
StarTech.com DP to HDMI Adapter with HDR | In Stock | £25.59 |
StarTech.com 2 Port HDMI KVM Switch | In Stock | £275.96 |
StarTech.com 4 Port HDMI KVM Switch | In Stock | £371.42 |
StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch | In Stock | £413.81 |
StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch | In Stock | £546.71 |
