StarTech.com 2 Port Dual Monitor HDMI KVM Switch
Quicklinx: GFJ5WS00 Mfr#: SV231DHU34K6
Type: KVM
Ports: 2
£323.32 ex VAT
£387.98 inc VAT
KVM with USB - TAA Compliant - USB 3.0 Hub - HDMI 2.0 - Digital & Analog Audio
This 2-port KVM switch combines 4K (60Hz) digital display capabilities with control of two connected computers.
4K 60Hz Picture and Full Audio Support
The HDMI KVM switch supports resolutions up to 4K at 60Hz. It drives two large monitors at the full 4K resolution. Includes EDID and HDCP signal emulation so monitors always remain synced for faster switching times, and desktop settings are maintained to avoid disrupting your workflow.
With support for digital audio (with supporting displays and sources) and separate 3.5 mm stereo audio, the HDMI 2.0 KVM switch delivers full audio compatibility.
Integrated USB Hub
The integrated USB 3.0 hub shares two peripherals (in addition to keyboard and mouse) among attached computers as if they were directly connected to your host computer, eliminating the cost of duplicate devices such as printers and scanners.
Windows, Mac & Linux Compatible
While supporting Windows, this HDMI KVM switch is also compatible with Mac and Linux operating systems.
Easy to Operate
The front-panel pushbuttons make it easy to switch between systems and activate the auto-scan feature. The hotkey functionality makes accessing each system quickly, while a buzzer sound confirms the switch.
StarTech.com offers a wide selection of high-quality KVM switches and KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice, and monitors.
This 2-port HDMI KVM switch is backed by a 2-year warranty and free lifetime technical support.
  • 4K 60Hz Picture and Full Audio Support
    The HDMI KVM switch supports resolutions up to 4K at 60Hz. It drives two large monitors at the full 4K resolution. Includes EDID and HDCP signal emulation so monitors always remain synced for faster switching times, and desktop settings are maintained to avoid disrupting your workflow. With support for digital audio (with supporting displays and sources) and separate 3.5 mm stereo audio, the HDMI 2.0 KVM switch delivers full audio compatibility.
  • Integrated USB Hub
StarTech.com 2 Port Dual Monitor HDMI KVM Switch, 4K 60Hz Ultra HD HDR, Desktop 4K HDMI 2.0 KVM Switch with 2 Port USB 3.0 Hub (5Gbps) & 4x USB 2.0 HID Port, Audio, Hotkey Switching, TAA - KVM with Fast Switching - KVM / audio switch - 2 ports - TAA Compliant
Subtype
KVM
Ports
2 x KVM / audio
7.1 channel audio support, HDR10 support
USB 1.1, USB 2.0, USB 3.0
AC 100-240 V
10 cm x 16 cm x 5.8 cm
Japan, New Zealand, North America, United Kingdom, Europe
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
Status
2 x HDMI output , 4 x HDMI input , 2 x USB 3.0 output Type A , 2 x USB 3.0 input Type B , 4 x USB 1.1 Type A , 2 x audio input mini-jack , 1 x audio output mini-jack , 1 x mini-USB Type B
External power adapter
Power Provided
DC 12 V - 3 A
AC 100-240 V
36 Watt
4 rubber feet
MTBF
156,000 hours
FCC, RoHS, EDID compatible, HDCP 2.2
TAA Compliant
10 cm
16 cm
5.8 cm
Shipping Width
23.8 cm
Shipping Depth
18.9 cm
Shipping Height
9.1 cm
0 - 80%
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
GFJ5 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £9.00
GFJ5 StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £10.31
GFJ5 StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.10
GFJ5 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.34
GFJ5 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.86
GFJ5 StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £19.66
GFJ5 StarTech.com 2m 6ft USB 3.0 C to B Cable In Stock £14.66
GFJ5 StarTech.com 3m USB 2.0 C to B Cable In Stock £16.73
GFJ5 StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £16.24
GFJ5 StarTech.com DP to HDMI Adapter with HDR In Stock £25.21
GFJ5 StarTech.com 2 Port HDMI KVM Switch In Stock £247.25
GFJ5 StarTech.com 4 Port HDMI KVM Switch In Stock £338.08
GFJ5 StarTech.com 2 Port Triple Monitor DisplayPort KVM Switch In Stock £376.72
GFJ5 StarTech.com 2 Port Quad Monitor DisplayPort KVM Switch In Stock £482.01
Type: KVM
Ports: 2
