This dual DisplayPort KVM switch combines next-generation digital display standards with seamless KVM control. The 2-port KVM switch features audio and USB peripheral support along with dual-display capability, which makes it easy to create a multimedia workstation that can switch between two dual-head or twin DisplayPort systems.
- StarTech.com 2-Port DisplayPort KVM Switch - Dual-Monitor - 4K 60 - with Audio & USB Peripheral Support - DP 1.2 - USB Hub (SV231DPDDUA2) - KVM / audio / USB switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- 4K resolution support
- Power
- AC 120/230 V / DC 12 V 0.6 A
- 16.1 cm x 10 cm x 5.75 cm
- 1.2 kg
- Black
- Localisation
- Australia, Japan, New Zealand, North America, United Kingdom, Europe
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 60 Hz
- 6 x DisplayPort , 3 x audio / headphones mini-jack , 3 x microphone input mini-jack , 4 x USB 2.0 Type A , 2 x USB Type B
- Power Device
- External power adapter
- Voltage Required
- Electric Current Required
- 0.6 A
- Black
- Included Accessories
- 4 rubber feet
- FCC, RoHS, WEEE, RCM
- Localisation
- 16.1 cm
- 10 cm
- 5.75 cm
- 1.2 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £240.14 |
StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.50 |
StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £189.49 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £287.60 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.06 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.00 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.48 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.06 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.34 |
StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £342.46 |
StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £245.82 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.71 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz | In Stock | £328.22 |
StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display | In Stock | £469.52 |
StarTech.com 2 Pt DisplayPort KVM | In Stock | £287.20 |
StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz | In Stock | £83.26 |
StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable | In Stock | £91.46 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £11.52 |
StarTech.com 2 Port USB C KVM Switch | In Stock | £85.71 |
StarTech.com 2 Port Hybrid USB-C KVM Switch | In Stock | £37.12 |
StarTech.com 2-Port Dual-Monitor KVM Switch | In Stock | £298.54 |
StarTech.com 4-Port Dual-Monitor KVM Switch | In Stock | £627.58 |
