Share and switch between two USB-A and DisplayPort-enabled computers, using this DisplayPort KVM Switch. Share an 8K 60Hz DisplayPort monitor, a keyboard and mouse, two USB 5Gbps devices, and two additional USB 2.0 devices.
High-Resolution 8K 60Hz Video
This KVM supports resolutions up to 8K 60Hz or 4K 144Hz/120Hz. Daisy chain additional monitors via MST pass-through. The KVM supports ultrawide resolutions of up to 5120x1440 at 60Hz. Ideal for applications such as CAD/CAM, video editing, and content creation. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and greater luminosity. -
Customizable Switching
This Universal KVM Switch provides various switching options, including hotkey or push-button switching. Hotkeys allow for independent switching of audio and video, enabling audio playback from one computer while controlling the other. An audible buzzer confirms hotkey input, and LEDs provide a visual status of the selected host. -
Universal Compatibility
The TAA-Compliant KVM Switch offers universal compatibility, working with all operating systems, including Windows, macOS, ChromeOS, and Linux. It is also compatible with all hardware platforms, including Intel and AMD. -
Reliable Performance
The durable metal housing helps prevent Electro-magnetic Interference (EMI). Overcurrent Protection (OCP) ensures peripherals don't overdraw power, reducing the occurrence of device dropouts or shutdowns.
- StarTech.com 2-Port DisplayPort KVM Switch, 8K 60Hz / 4K 144Hz, Single Display, DP 1.4, 2x USB 3.0 Ports, 4x USB 2.0 HID Ports, Push-Button & Hotkey Switching, TAA Compliant - OS Independent, Metal Housing (D86A2-2-PORT-8K-KVM) - KVM / audio / USB switch - 2 ports - TAA Compliant
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Performance
- Data transfer rate: 5 Gbps
- Push button, hotkeys
- Power
- AC 100-240 V 1 A
- 16 cm x 10 cm x 4 cm
- 600 g
- Black
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Performance
- Max Resolution
- 7680 x 4320 @ 60 Hz
- Push button, hotkeys, Auto Scan mode, ultrawide resolutions support
- Status Indicators
- Power
- 1 x DisplayPort output , 2 x DisplayPort input , 4 x USB 2.0 Type A , 2 x USB 3.0 Type A , 2 x USB 3.2 Gen 1 Type B , 2 x audio input mini-jack , 1 x audio output mini-jack
- Power Device
- External power adapter
- Power Provided
- 3 A
- Voltage Required
- AC 100-240 V
- Electric Current Required
- 1 A
- 36 Watt
- Black
- Included Accessories
- 4 rubber feet
- MTBF
- 130,000 hours
- FCC Part 15, RoHS, WEEE, DisplayPort 1.4, DSC, HDCP
- TAA Compliant
- 16 cm
- 10 cm
- 4 cm
- 600 g
- Shipping Width
- 23.8 cm
- Shipping Depth
- 18.4 cm
- Shipping Height
- 8.9 cm
- Shipping Weight
- 1 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80% RH (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £15.54 |
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £15.15 |
StarTech.com 10ft DisplayPort 1.4 8K 60Hz | In Stock | £21.32 |
StarTech.com 4-Port DP KVM Switch, 8K 60Hz | In Stock | £378.68 |
StarTech.com 4-Port DisplayPort KVM Switch | In Stock | £360.65 |
StarTech.com Dual-Monitor DP 1.4 KVM Switch | In Stock | £399.05 |
