StarTech.com 2-Port DisplayPort MST Hub
Quicklinx: H4PSWS00 Mfr#: MST14DP122DP
£28.32 ex VAT
£33.98 inc VAT
This DisplayPort to DisplayPort MST Hub enables a connection to two DP monitors, using a single DisplayPort enabled host device.
  • 4K at 60Hz and HDR
    Multi-Stream Transport (MST) technology combines multiple video signals into a single output signal/stream. This MST Hub separates the single input stream into two independent signals, one for each DisplayPort enabled display. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and luminosity. *Please verify the GPU capabilities and driver support for DSC through MST with the OEM of the host device
  • Multitasking Made Easy
    Configure the dual-DP displays in extended or mirrored mode. Create a high-performance workstation by adding two independent 4K 60Hz displays. This empowers increased multi-tasking across your organization, resulting in increased productivity.
  • Hassle-Free Setup
    This MST Hub works with DisplayPort enabled Windows devices featuring 11th generation (and later) processors, or dedicated graphics cards that have a DisplayPort 1.4 output. Plug-and-play installation, with no drivers or software required. The 12in (30cm) built-on cable provides options for flexible installation configurations, reducing the amount of strain on ports and connectors. Additionally, this dual-monitor splitter is USB Powered and comes with the USB Micro-B power cable. This product is backed for 3 years, including free lifetime 24/5 multilingual technical assistance.
StarTech.com 2-Port DisplayPort MST Hub, Dual 4K 60Hz, DP to 2x DisplayPort Monitor Adapter, DP 1.4 Multi-Monitor Video Adapter w/ 1ft Built-in Cable, USB Powered, Windows Only - Multi Stream Transport Hub (MST14DP122DP) - hub - 2 ports
Hub - 2 ports
Ports
1 x DisplayPort + 1 x micro-USB + 2 x DisplayPort
DisplayPort MST support, dual display support, HDR support, 2x4K60Hz support, extended display mode, video mirror mode
10.5 cm 1.4 cm
53 g
Space grey
Windows 10, Windows 11
3-year warranty
Hub - 2 ports
Ports
Space grey
10.5 cm
1.4 cm
53 g
Shipping Width
14.2 cm
Shipping Height
3 cm
Shipping Weight
110 g
Limited warranty - technical support - 3 years
5 - 90% RH (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
H4PS StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £12.20
H4PS StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.78
H4PS StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £14.40
H4PS StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £14.98
H4PS StarTech.com 10ft DisplayPort 1.4 8K 60Hz In Stock £21.09
H4PS StarTech.com 3-Port DisplayPort MST Hub In Stock £29.06
