This DisplayPort to DisplayPort MST Hub enables a connection to two DP monitors, using a single DisplayPort enabled host device.
4K at 60Hz and HDR
Multi-Stream Transport (MST) technology combines multiple video signals into a single output signal/stream. This MST Hub separates the single input stream into two independent signals, one for each DisplayPort enabled display. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and luminosity. *Please verify the GPU capabilities and driver support for DSC through MST with the OEM of the host device -
Multitasking Made Easy
Configure the dual-DP displays in extended or mirrored mode. Create a high-performance workstation by adding two independent 4K 60Hz displays. This empowers increased multi-tasking across your organization, resulting in increased productivity. -
Hassle-Free Setup
This MST Hub works with DisplayPort enabled Windows devices featuring 11th generation (and later) processors, or dedicated graphics cards that have a DisplayPort 1.4 output. Plug-and-play installation, with no drivers or software required. The 12in (30cm) built-on cable provides options for flexible installation configurations, reducing the amount of strain on ports and connectors. Additionally, this dual-monitor splitter is USB Powered and comes with the USB Micro-B power cable. This product is backed for 3 years, including free lifetime 24/5 multilingual technical assistance.
- StarTech.com 2-Port DisplayPort MST Hub, Dual 4K 60Hz, DP to 2x DisplayPort Monitor Adapter, DP 1.4 Multi-Monitor Video Adapter w/ 1ft Built-in Cable, USB Powered, Windows Only - Multi Stream Transport Hub (MST14DP122DP) - hub - 2 ports
- Hub - 2 ports
- Ports
- 1 x DisplayPort + 1 x micro-USB + 2 x DisplayPort
- DisplayPort MST support, dual display support, HDR support, 2x4K60Hz support, extended display mode, video mirror mode
- 10.5 cm 1.4 cm
- 53 g
- Space grey
- System Requirements
- Windows 10, Windows 11
- 3-year warranty
- Hub - 2 ports
- Ports
- Space grey
- OS Required
- 10.5 cm
- 1.4 cm
- 53 g
- Shipping Width
- 14.2 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 110 g
- Limited warranty - technical support - 3 years
- 0 °C
- 40 °C
- 5 - 90% RH (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
StarTech.com 2m 6.6ft DisplayPort 1.4 Cable | In Stock | £11.86 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.66 |
StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £14.40 |
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £14.98 |
StarTech.com 10ft DisplayPort 1.4 8K 60Hz | In Stock | £21.09 |
StarTech.com 3-Port DisplayPort MST Hub | In Stock | £27.02 |
