The Video Matrix KVM Switch allows you to view one display from each connected computer and switch the keyboard, mouse, and audio device between the currently selected displays using hotkeys. It also functions as a standard KVM, switching all connected peripherals and both monitors. This TAA-Compliant KVM Switch provides BIOS/UEFI control and works with any operating system, including Windows, macOS, and Linux, without requiring software. It is compatible with all hardware platforms such as Intel, AMD, and Apple Silicon. Switching KVM ports is simple with the front-facing push button, hotkeys, or the included remote selector cable. An audible buzzer provides confirmation, and LEDs offer quick visual port selection status. Eliminate the need to connect 3.5mm cables from the computers to the KVM by using this KVM switch's built-in USB audio device, which provides 3.5mm audio jacks for both microphone and speakers. This setup simplifies your workspace by integrating audio management directly into the KVM switch. The durable steel housing helps protect against Electro-Magnetic Interference (EMI), enhancing stability and reliability. Its sturdy construction makes it ideal for various environments, offering 8kV Air/6kV Contact ESD protection.
Universal Compatibility
The TAA-Compliant KVM Switch provides BIOS/UEFI control and works with any operating system, including Windows, macOS, and Linux. No software is required, and it is compatible with all hardware platforms such as Intel, AMD, and Apple Silicon. -
Customizable Switching
Switching KVM ports is easy with the front-facing push button, hotkeys, or the included remote selector cable. An audible buzzer provides confirmation, and LEDs offer quick visual port selection status. -
Reliable Performance
The durable design features a steel housing that helps prevent Electro-Magnetic Interference (EMI), enhancing the stability and reliability of the KVM. Its sturdy construction makes it ideal for installation in a variety of environments, and it offers 8kV Air/6kV Contact ESD protection. -
USB Audio
Eliminate the need to connect 3.5mm cables from the computers to the KVM by using this KVM switch's built-in USB audio device, which provides 3.5mm audio jacks for both microphone and speakers. This setup simplifies your workspace by integrating audio management directly into the KVM switch. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • USB Event Monitoring Utility: Track and log connected USB devices.
 - StarTech.com 2-Port Dual-Monitor DP KVM Switch w/Video Matrix, 4K 60Hz - KVM / audio / USB switch - 2 ports - TAA Compliant
- Subtype
 - KVM
- Ports
 - 2 x KVM / audio / USB
- KVM Users Qty
 - 1 local user
 - EMI protection, 8KV ESD Protector (air-gap discharge), 6KV ESD Protector (contact discharge), 4K resolution support, push button, hotkeys, built-in buzzer, LED status indicator, 10-bit Deep Colour support, 4:4:4 chroma subsampling support, aluminium/steel housing, Auto Scan Mode, wide screen supported
 - USB 2.0
- Power
 - AC 100-240 V 1 A
 - 10.5 cm x 22.1 cm x 2.6 cm
 - 626 g
 - Black
- Localisation
 - North America, Europe, United Kingdom, Australia, New Zealand
- TAA Compliant
 - 2-year warranty
- Enclosure Type
 - Desktop
- Subtype
 - KVM
- Ports
- KVM Local Users Qty
 - 1 local user
- Keyboard / Mouse Interface
 - USB
- Max Resolution
 - 3840 x 2160 @ 60 Hz
 - USB 2.0
- Status Indicators
 - Status
 - 2 x DisplayPort output console , 1 x microphone output mini-jack console , 1 x headphones output mini-jack console , 2 x USB 2.0 output Type A , 2 x USB Human Interface Device (HID) , 4 x DisplayPort input , 2 x USB 2.0 input Type B , 1 x remote control
- Power Device
 - External power adapter
- Power Provided
 - DC 12 V - 3 A
- Voltage Required
 - AC 100-240 V
- Electric Current Required
 - 1 A
 - 36 Watt
 - Black
- Included Accessories
 - International power plugs, remote control cable
- MTBF
 - 87,298 hours
 - WEEE, RoHS, FCC
- TAA Compliant
- Localisation
 - 10.5 cm
 - 22.1 cm
 - 2.6 cm
 - 626 g
- Shipping Width
 - 25 cm
- Shipping Depth
 - 29.2 cm
- Shipping Height
 - 7.8 cm
- Shipping Weight
 - 1.5 kg
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
 - 0 - 90% RH (non-condensing)
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 60 °C
                        StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £11.55 |
