StarTech.com 2-Port DisplayPort KVM Switch
Quicklinx: J4LNWS00 Mfr#: P2ADD121D-KVM-SWITCH
Type: KVM / audio / USB switch
Ports: 2
Connectivity: KVM
18 In Stock
£308.62 ex VAT
£370.34 inc VAT
The Video Matrix KVM Switch allows you to view one display from each connected computer and switch the keyboard, mouse, and audio device between the currently selected displays using hotkeys. It also functions as a standard KVM, switching all connected peripherals and both monitors. This TAA-Compliant KVM Switch provides BIOS/UEFI control and works with any operating system, including Windows, macOS, and Linux, without requiring software. It is compatible with all hardware platforms such as Intel, AMD, and Apple Silicon. Switching KVM ports is simple with the front-facing push button, hotkeys, or the included remote selector cable. An audible buzzer provides confirmation, and LEDs offer quick visual port selection status. Eliminate the need to connect 3.5mm cables from the computers to the KVM by using this KVM switch's built-in USB audio device, which provides 3.5mm audio jacks for both microphone and speakers. This setup simplifies your workspace by integrating audio management directly into the KVM switch. The durable steel housing helps protect against Electro-Magnetic Interference (EMI), enhancing stability and reliability. Its sturdy construction makes it ideal for various environments, offering 8kV Air/6kV Contact ESD protection.
  • Universal Compatibility
    The TAA-Compliant KVM Switch provides BIOS/UEFI control and works with any operating system, including Windows, macOS, and Linux. No software is required, and it is compatible with all hardware platforms such as Intel, AMD, and Apple Silicon.
  • Customizable Switching
    Switching KVM ports is easy with the front-facing push button, hotkeys, or the included remote selector cable. An audible buzzer provides confirmation, and LEDs offer quick visual port selection status.
  • Reliable Performance
    The durable design features a steel housing that helps prevent Electro-Magnetic Interference (EMI), enhancing the stability and reliability of the KVM. Its sturdy construction makes it ideal for installation in a variety of environments, and it offers 8kV Air/6kV Contact ESD protection.
  • USB Audio
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • USB Event Monitoring Utility: Track and log connected USB devices.
StarTech.com 2-Port Dual-Monitor DP KVM Switch w/Video Matrix, 4K 60Hz - KVM / audio / USB switch - 2 ports - TAA Compliant
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
EMI protection, 8KV ESD Protector (air-gap discharge), 6KV ESD Protector (contact discharge), 4K resolution support, push button, hotkeys, built-in buzzer, LED status indicator, 10-bit Deep Colour support, 4:4:4 chroma subsampling support, aluminium/steel housing, Auto Scan Mode, wide screen supported
USB 2.0
AC 100-240 V 1 A
10.5 cm x 22.1 cm x 2.6 cm
626 g
North America, Europe, United Kingdom, Australia, New Zealand
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
USB 2.0
Status Indicators
Status
2 x DisplayPort output console , 1 x microphone output mini-jack console , 1 x headphones output mini-jack console , 2 x USB 2.0 output Type A , 2 x USB Human Interface Device (HID) , 4 x DisplayPort input , 2 x USB 2.0 input Type B , 1 x remote control
External power adapter
Power Provided
DC 12 V - 3 A
AC 100-240 V
Electric Current Required
1 A
36 Watt
International power plugs, remote control cable
MTBF
87,298 hours
WEEE, RoHS, FCC
TAA Compliant
10.5 cm
22.1 cm
2.6 cm
626 g
Shipping Width
25 cm
Shipping Depth
29.2 cm
Shipping Height
7.8 cm
Shipping Weight
1.5 kg
0 - 90% RH (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
J4LN StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.12
Ports: 2
Connectivity: KVM
