StarTech.com 2-Port DisplayPort + HDMI KVM
Quicklinx: J4LPWS00 Mfr#: P2ADDH462-KVM-SWITCH
Type: KVM / audio / USB switch
Ports: 2
Connectivity: KVM
£288.68 ex VAT
£346.41 inc VAT
The 2-Port Dual-Monitor DisplayPort and HDMI KVM Switch allows control of two systems with a single keyboard and mouse, providing both HDMI and DisplayPort interfaces for versatile connectivity. Experience visuals with support for resolutions up to 3840 x 2160 at 60 Hz, ensuring clarity and detail in every display. This KVM switch is designed for durability and efficiency, featuring a robust metal housing, EMI protection, and multiple ESD protections for reliability in various environments. The user-friendly design incorporates built-in indicators and push button controls for easy operation, along with hotkey functionality for swift switching between systems.
With a maximum operating temperature range of 0 °C to 40 °C and a humidity range of 0-90% RH, this switch is reliable in diverse conditions. Suitable for both home and professional setups, it supports 7.1 channel audio for a complete multimedia experience. This device is compliant with RoHS and WEEE standards, ensuring environmentally friendly operation and longevity.
  • Robust design
    The KVM switch features a sturdy metal and steel housing designed to withstand regular use while providing EMI protection to minimize interference.
  • High-resolution support
    Capable of supporting 4K resolutions, users can enjoy crisp and detailed visuals across dual monitors, enhancing productivity and entertainment.
  • Multiple connectivity options
    Equipped with various input and output types including HDMI, DisplayPort, and USB, ensuring compatibility with a wide range of devices.
  • User-friendly controls
    Includes an integrated buzzer, LED indicators, and push button along with hotkeys, making switching between systems smooth and intuitive.
  • Reliable performance
    Boasting an MTBF of over 138,000 hours, this KVM switch is built for long-term usage, minimizing downtime and maintenance needs.
StarTech.com 2-Port Dual-Monitor DisplayPort en HDMI KVM Switch, 4K 60Hz - KVM / audio / USB switch - 2 ports - TAA Compliant
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
EMI protection, steel housing, metal housing, 8KV ESD Protector (air-gap discharge), 6KV ESD Protector (contact discharge), 4K resolution support, push button, hotkeys, built-in buzzer, LED status indicator, 7.1 channel audio support
USB 3.2 Gen 1, USB 2.0, USB 3.0
AC 100-240 V 1 A
10 cm x 16.3 cm x 6.6 cm
750 g
North America, Europe, United Kingdom, Australia, New Zealand
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
Host, hub
1 x DisplayPort output console , 1 x HDMI output console , 2 x USB 2.0 output Type A console , 2 x USB 3.0 output Type A console , 1 x microphone output mini-jack console , 1 x headphones output mini-jack console , 2 x DisplayPort input , 2 x HDMI input , 2 x USB 3.0 input Type B , 2 x microphone input mini-jack , 2 x headphones input mini-jack
External power adapter
Power Provided
DC 12 V - 3 A
AC 100-240 V
Electric Current Required
1 A
36 Watt
International power plugs
MTBF
138,390 hours
WEEE, RoHS
TAA Compliant
10 cm
16.3 cm
6.6 cm
750 g
Shipping Width
16.2 cm
Shipping Depth
33.2 cm
Shipping Height
12.8 cm
0 - 90% RH (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
J4LP StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
J4LP StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.85
J4LP StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £11.52
Ports: 2
Connectivity: KVM
