The 2-Port Dual-Monitor DisplayPort and HDMI KVM Switch allows control of two systems with a single keyboard and mouse, providing both HDMI and DisplayPort interfaces for versatile connectivity. Experience visuals with support for resolutions up to 3840 x 2160 at 60 Hz, ensuring clarity and detail in every display. This KVM switch is designed for durability and efficiency, featuring a robust metal housing, EMI protection, and multiple ESD protections for reliability in various environments. The user-friendly design incorporates built-in indicators and push button controls for easy operation, along with hotkey functionality for swift switching between systems.
With a maximum operating temperature range of 0 °C to 40 °C and a humidity range of 0-90% RH, this switch is reliable in diverse conditions. Suitable for both home and professional setups, it supports 7.1 channel audio for a complete multimedia experience. This device is compliant with RoHS and WEEE standards, ensuring environmentally friendly operation and longevity.
Robust design
The KVM switch features a sturdy metal and steel housing designed to withstand regular use while providing EMI protection to minimize interference. -
High-resolution support
Capable of supporting 4K resolutions, users can enjoy crisp and detailed visuals across dual monitors, enhancing productivity and entertainment. -
Multiple connectivity options
Equipped with various input and output types including HDMI, DisplayPort, and USB, ensuring compatibility with a wide range of devices. -
User-friendly controls
Includes an integrated buzzer, LED indicators, and push button along with hotkeys, making switching between systems smooth and intuitive. -
Reliable performance
Boasting an MTBF of over 138,000 hours, this KVM switch is built for long-term usage, minimizing downtime and maintenance needs.
- StarTech.com 2-Port Dual-Monitor DisplayPort en HDMI KVM Switch, 4K 60Hz - KVM / audio / USB switch - 2 ports - TAA Compliant
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- EMI protection, steel housing, metal housing, 8KV ESD Protector (air-gap discharge), 6KV ESD Protector (contact discharge), 4K resolution support, push button, hotkeys, built-in buzzer, LED status indicator, 7.1 channel audio support
- USB 3.2 Gen 1, USB 2.0, USB 3.0
- Power
- AC 100-240 V 1 A
- 10 cm x 16.3 cm x 6.6 cm
- 750 g
- Black
- Localisation
- North America, Europe, United Kingdom, Australia, New Zealand
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Status Indicators
- Host, hub
- 1 x DisplayPort output console , 1 x HDMI output console , 2 x USB 2.0 output Type A console , 2 x USB 3.0 output Type A console , 1 x microphone output mini-jack console , 1 x headphones output mini-jack console , 2 x DisplayPort input , 2 x HDMI input , 2 x USB 3.0 input Type B , 2 x microphone input mini-jack , 2 x headphones input mini-jack
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 3 A
- Voltage Required
- AC 100-240 V
- Electric Current Required
- 1 A
- 36 Watt
- Black
- Included Accessories
- International power plugs
- MTBF
- 138,390 hours
- WEEE, RoHS
- TAA Compliant
- Localisation
- 10 cm
- 16.3 cm
- 6.6 cm
- 750 g
- Shipping Width
- 16.2 cm
- Shipping Depth
- 33.2 cm
- Shipping Height
- 12.8 cm
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% RH (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.83 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.12 |
