StarTech.com 2-Port 2.5G PCIe Network Card
Quicklinx: HDG7WS00 Mfr#: PR22GI-NETWORK-CARD
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Fast Ethernet, Ethernet, 2.5 Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
17 In Stock
£121.39 ex VAT
£145.66 inc VAT
This dual-port 2.5 GbE network interface card (NIC) features an Intel I225-V chipset with Intel vPro technology, to enhance performance and data integrity across two 2.5G Ethernet connections. Utilize existing Cat5e or CAT6 cabling infrastructure while adding NBASE-T (802.3bz) compatibility for seamless integration.
  • IT manageability
    Intel vPro for remote management and troubleshooting, PXE boot enabled to deployment speeds/updates, 9K jumbo frame for reduced packet overhead, remotely boot a system using WoL, VLAN support for efficient network management.
  • Build quality
    LAN card features: built-in heatsink to keep controller chips running cool and for optimal performance, LED indicators for link status/speed, LAN transformers maintain signal quality and reduced EMI for reliable communication.
  • Increased network speed
    The PCIe network card leverages Intel vPro technology for remote management and troubleshooting capabilities. Improve bandwidth for data-intensive applications, network sharing, FTPs, online or local storage/backup, and the streaming of online content - while reducing network slowdowns. Access up to 2.5GBASE-T speeds using Cat5e (or better) cabling, to maximize existing networks and equipment.
  • Enhance existing hardware
    The network interface card connects via an available x2 PCI Express 2.0 (or higher) expansion slot. The card ships in a standard-profile bracket and includes a low-profile bracket for installation into small form factor systems and servers.
StarTech.com 2-Port 2.5Gbps NBASE-T PCIe Network Card, Intel I225-V, Dual-Port Computer Network Card, Multi-Gigabit NIC, PCI Express Server LAN Card, Desktop Ethernet Interface - network adapter - PCIe 2.0 x2 - 10M/100M/1G/2.5 Gigabit Ethernet x 2
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x2
PCI Specification Revision
PCIe 2.0
Ports
11 cm x 12 cm x 1.8 cm
60 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Jumbo frame size: 9000
Intel I225-V
IEEE 802.3bz, IEEE 1588v1, IEEE 802.1as, IEEE 802.1p, IEEE 802.1Q, IEEE 802.1x, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE P802.3az
Microsoft Windows 10 / 11, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Linux 5.8.x or later (LTS versions only)
Network adapter
PCI Express 2.0 x2
PCIe 2.0
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
2.5 Gbps
Status Indicators
Link/activity/speed
PXE boot, Intel vPro Technology support, full duplex capability, Auto MDIX, auto-negotiation, VLAN support, WOL, bus powered
Processor / Memory
Intel I225-V
2 x 2.5 GBase-T - RJ-45
Low-profile bracket
RCM, WEEE, IEEE 1588
11 cm
12 cm
1.8 cm
60 g
Limited warranty - 2 years , Technical support - assistance - lifetime
55 °C
5 - 90% RH
HDG7 StarTech.com 1-Port 2.5G PCIe Network Card In Stock £35.26
HDG7 StarTech.com 4-Port RJ45 1G OCP 3.0 NIC In Stock £244.75
Protocol: Fast Ethernet
Protocol: Ethernet
Protocol: 2.5 Gigabit Ethernet
