StarTech.com 2-Port 10G Fiber NIC-Open SFP+
Quicklinx: BLHDWS00 Mfr#: PEX20000SFPI
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC, Unix
Type: Network adapter
10 In Stock
£301.73 ex VAT
£362.07 inc VAT
Add two 10 Gigabit Fiber Ethernet ports (10 Gbps per port) to your server or workstation - using the SFP+ transceiver of your choice. Get fast, high-bandwidth connectivity with this cost-effective fiber network card. It adds two open SFP+ slots to your server or high-powered workstation, giving you an easy way to connect your server or workstation to a 10 Gigabit fiber network using the SFP+ modules of your choice.
Large file transfers, multimedia content and increased numbers of network users create constant pressures for more bandwidth in your network infrastructure. This fiber NIC lets you harness the speed and stability of a 10 Gigabit network. The NIC supports data transfers at up to 10Gbps per port, or up to 20Gbps per port in full-duplex mode.
The fiber NIC is compatible with most 10GbE SFP+ transceivers, giving you flexible configuration options to connect your computer directly to a fiber network at greater distances.
The card features two open SFP+ slots with support for interchangeable SFP+ modules, including the SFP10GSRST" text="StarTech.com 10GBase-SR SFP+ Fiber Transceiver Module (SKU: SFP10GSRST). This gives you the option to use the modules that best suit your network needs based on distance and connector type. StarTech.com provide a dependable solution for linking telecom and data communications equipment, such as routers and switches, in Gigabit Ethernet and fibre channel applications.
The 10 Gigabit network card features the Intel 82599 chipset, designed to deliver the power, performance and enhanced capabilities you need for reliable network connections to your server or computer. The Intel chip offers many advanced features including Intel Virtualization Technology for connectivity, PXE network boot support and up to 15K jumbo frame support.
  • Flexible connectivity options
    The network card features two SFP+ multimode LC fiber connectors, allowing versatility in connection types and enabling optimized setups for any environment.
  • High-performance data transfer
    With a data transfer rate of 10 Gbps and forwarding performance of 20 Gbps in full duplex mode, this card ensures efficient communication across your network.
  • Robust environmental adaptability
    Designed to operate within a temperature range of 5°C to 50°C and a humidity range of 20% to 80%, this card is equipped to handle various conditions.
  • Compliance with industry standards
    The network card meets several essential standards including FCC and RoHS, ensuring it aligns with regulatory requirements for safety and environmental considerations.
  • Efficient jumbo frame support
    The capability to support jumbo frames up to 15,000 bytes enhances data throughput and is beneficial for applications that require high transfer efficiency.
StarTech.com 10G Network Card - 2x 10G Open SFP+ Multimode LC Fiber Connector - Intel 82599 Chip - Gigabit Ethernet Card (PEX20000SFPI) - network adapter - PCIe 2.0 x8
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x8
1.8 cm x 13.5 cm x 12 cm
102 g
Cabling Type
Ethernet 10GBase-LR, Ethernet 10GBase-SR, Ethernet 10GBase-LRM
10GbE
Data Transfer Rate
10 Gbps
Performance
Forwarding performance (full duplex): 20 Gbps
Jumbo frame size: 15000
Intel 82599
IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae
Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x LTS versions, Microsoft Windows Server 2019 (64-bit)
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRSST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRXST, TB31PCIEX16
Network adapter
PCI Express 2.0 x8
Wired
Cabling Type
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Performance
Full duplex capability, Jumbo Frames support
Processor / Memory
Intel 82599
2 - SFP+
Low-profile bracket
FCC, RoHS
1.8 cm
13.5 cm
12 cm
102 g
5 °C
50 °C
20 - 80% (non-condensing)
P/N: 455883B21ST, BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, ET10GSFP, EXSFP10GELRS, EXSFP10GESRS, J9150AST, J9151AST, J9152AST, JD094BST, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRMST, SFP10GLRSST, SFP10GLRST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRST, SFP10GSRSTTA, SFP10GSRXST, TB31PCIEX16
BLHD StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £36.36
BLHD StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £40.56
BLHD StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £46.24
BLHD StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £60.13
BLHD StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £35.41
BLHD StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £301.73
BLHD StarTech.com 2-Port SFP+ OCP Network Card In Stock £289.13
Compatibility: PC
Compatibility: Unix
