Add two 10 Gigabit Fiber Ethernet ports (10 Gbps per port) to your server or workstation - using the SFP+ transceiver of your choice. Get fast, high-bandwidth connectivity with this cost-effective fiber network card. It adds two open SFP+ slots to your server or high-powered workstation, giving you an easy way to connect your server or workstation to a 10 Gigabit fiber network using the SFP+ modules of your choice.
Large file transfers, multimedia content and increased numbers of network users create constant pressures for more bandwidth in your network infrastructure. This fiber NIC lets you harness the speed and stability of a 10 Gigabit network. The NIC supports data transfers at up to 10Gbps per port, or up to 20Gbps per port in full-duplex mode.
The fiber NIC is compatible with most 10GbE SFP+ transceivers, giving you flexible configuration options to connect your computer directly to a fiber network at greater distances.
The card features two open SFP+ slots with support for interchangeable SFP+ modules, including the SFP10GSRST" text="StarTech.com 10GBase-SR SFP+ Fiber Transceiver Module (SKU: SFP10GSRST). This gives you the option to use the modules that best suit your network needs based on distance and connector type. StarTech.com provide a dependable solution for linking telecom and data communications equipment, such as routers and switches, in Gigabit Ethernet and fibre channel applications.
The 10 Gigabit network card features the Intel 82599 chipset, designed to deliver the power, performance and enhanced capabilities you need for reliable network connections to your server or computer. The Intel chip offers many advanced features including Intel Virtualization Technology for connectivity, PXE network boot support and up to 15K jumbo frame support.
- StarTech.com 10G Network Card - 2x 10G Open SFP+ Multimode LC Fiber Connector - Intel 82599 Chip - Gigabit Ethernet Card (PEX20000SFPI) - network adapter - PCIe 2.0 x8
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 2.0 x8
- 1.8 cm x 13.5 cm x 12 cm
- 102 g
- Cabling Type
- Ethernet 10GBase-LR, Ethernet 10GBase-SR, Ethernet 10GBase-LRM
- Data Link Protocol
- 10GbE
- Data Transfer Rate
- 10 Gbps
- Performance
- Forwarding performance (full duplex): 20 Gbps
- Capacity
- Jumbo frame size: 15000
- Processor
- Intel 82599
- IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae
- Black
- System Requirements
- Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x LTS versions, Microsoft Windows Server 2019 (64-bit)
- 2-year warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRSST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRXST, TB31PCIEX16
- Network adapter
- Form Factor
- Connectivity Technology
- Wired
- Cabling Type
- 10 Gigabit Ethernet
- 10 Gbps
- Performance
- Capacity
- Full duplex capability, Jumbo Frames support
Processor / Memory
- Processor
- Intel 82599
- 2 - SFP+
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Black
- OS Required
- 1.8 cm
- 13.5 cm
- 12 cm
- 102 g
- Limited warranty - 2 years
- 5 °C
- 50 °C
- 20 - 80% (non-condensing)
- Designed For
- P/N: 455883B21ST, BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, ET10GSFP, EXSFP10GELRS, EXSFP10GESRS, J9150AST, J9151AST, J9152AST, JD094BST, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRMST, SFP10GLRSST, SFP10GLRST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRST, SFP10GSRSTTA, SFP10GSRXST, TB31PCIEX16
StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £37.38 |
StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £41.62 |
StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £47.44 |
StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £61.71 |
StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m | In Stock | £36.24 |
StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £304.01 |
StarTech.com PCIe Fiber Optic NIC w/ SFP+ | In Stock | £237.18 |
StarTech.com SFP+ Card 10 Gbps, PCIE NIC | In Stock | £122.36 |
StarTech.com 2-Port SFP+ OCP Network Card | In Stock | £290.26 |
