StarTech.com 2-Port  4K HDMI Video Switch
Quicklinx: BRVHWS00 Mfr#: VS221HD4KA
Type: Video/audio switch
Connectivity: HDMI
Ports: 2
Hurry, only 2 left in stock!
£86.28 ex VAT
£103.53 inc VAT
Switch between two HDMI sources on a single HDMI display, with 4K video resolution and fast switching for minimal disruption. Create a powerful visual experience, with the ability to switch between two 4K video sources seamlessly. This 2-port HDMI switch lets you share a 4K monitor, projector or TV with two different HDMI enabled video sources, and switch between them with minimal disruption.
The video switch maintains Ultra HD 4K picture quality while switching between content from HDMI source devices - including Blu-ray players or DVD players, computer systems, video game consoles, digital cable and satellite boxes and A/V receivers.
4K support ensures a higher level of image clarity and visibility, delivering four times the resolution of 1080p - 8.29 million pixels versus 2.07 million pixels. It provides a more engaging visual experience for audiences in a wide range of venues including conference centers and boardrooms, home theaters, and commercial settings. With its exceptional image quality, 4K resolution is also ideal for bringing your digital signage to life.
Fast auto switching: ensures minimal time for switching between HDMI sources. The switch provides effortless operation with advanced auto-sensing - it detects the latest connected HDMI source and automatically switches to it. Auto switching encourages collaboration among colleagues, by making it easy to share your projector. It also ensures no downtime in a digital signage application if a source signal is accidentally powered off or fails.
Priority switching: identifies one port to take first priority for HDMI sources when multiple sources are connected, ideal for applications such as digital signage.
Manual switching: enables you to manually select your HDMI source with front-panel buttons that are easy to use.
An IR remote control is included in the box, enabling you to easily select your desired input source remotely.
The switch also saves time during setup with EDID emulation, which ensures that all of your display settings, such as native resolution and refresh rate, are communicated between your display and video source devices. EDID emulation maximizes compatibility with your 4K display to ensure a convenient plug-and-play installation and the sharpest image quality.
  • Efficient video switching
    This device allows for automatic switching between two HDMI inputs, which makes it convenient for users who frequently switch between devices.
  • High-quality resolution support
    Capable of handling 4K resolution, this switch ensures that every detail is displayed clearly, making it suitable for high-definition viewing.
  • Robust audio capabilities
    Supports 7.1 channel audio, which enhances the overall sound experience, allowing users to enjoy their multimedia content with fidelity.
  • Easy installation
    With a simple setup process and an external power adapter, this switch can be integrated into any multimedia system without hassle.
  • Environmentally compliant
    Designed to meet standards such as FCC, RoHS, WEEE, and RCM, this product promotes sustainability while delivering performance.
StarTech.com 2-Port HDMI Automatic Video Switch - 4K 2x1 HDMI Switch with Fast Switching, Auto-Sensing and Serial Control (VS221HD4KA) - video/audio switch - 2 ports
Video/audio switch - 2 ports
Subtype
HDMI
Ports
2 x HDMI
4K resolution support, 7.1 channel audio support
AC 120/230 V
Australia, North America, United Kingdom, Europe
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Status Indicators
Port status, power
1 x HDMI input , 2 x HDMI output
External power adapter
AC 120/230 V
Remote control
1 x RJ-11 phone cable , 1 x DB-9 to RJ-11 adapter
FCC, RoHS, WEEE, RCM
50 °C
BRVH StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.91
BRVH StarTech.com 4-Port 4K HDMI Video Switch In Stock £115.03
BRVH StarTech.com 2-Port 4K HDMI Video Switch In Stock £86.28
BRVH StarTech.com 2x2 HDMI Matrix Switch - 4K In Stock £137.08
BRVH StarTech.com 4-Port HDMI Switch - 4K In Stock £36.90
BRVH StarTech.com 2-Port HDMI Switch - 4K In Stock £30.51
Connectivity: HDMI
Ports: 2
