This 2-pack of 1U rack shelves adds low-profile storage to any EIA-310-compliant 19-inch server rack or cabinet. The shelf is vented to improve airflow to mission-critical equipment. Cage nuts, screws, and washers are included for installation.
Robust Shelf
This 16-gauge SPCC steel server rack shelf features a maximum weight capacity of 44lb (20kg). -
Efficient Use of Space
The 1U cantilever shelf optimizes the workspace by storing tools, peripherals, or non-rackmount equipment, saving desk or floor space. Ideal for SOHO environments, server rooms, and other space-constrained locations.
- StarTech.com 2-Pack 1U Server Rack Shelf, Vented, 44lb Capacity, 16" Deep (CABSHELF116V2PK) - rack shelf - 1U
- Product Type
- Rack shelf
- Packaged Quantity
- 2 (specifications are for single item)
- Package Content
- 8 M6 cage nuts, 8 M6 screws, 8 M6 plastic washers
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- SPCC cold rolled steel
- 48.3 cm x 40 cm x 4.3 cm
- 3.1 kg
- Vented
- Limited lifetime warranty
- Packaged Quantity
- Product Type
- Rack shelf
- Product Material
- Package Content
- Rack Size
- 19"
- 1U
- 48.3 cm
- 40 cm
- 4.3 cm
- 3.1 kg
- Shipping Dimensions (WxDxH) / Weight
- 57 cm x 51 cm x 12 cm / 7 kg
- Black
- Weight Limit
- 20 kg
- Mounting Kit
- Included
- Vented
- EIA-310, ECA-310
- Limited warranty: - lifetime
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £19.93 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.74 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £35.09 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.28 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £62.33 |
