This 2 m (6.5 ft.) white USB C to Lightning cable withstands the daily demands of charging and syncing your iPad, iPhone or other mobile devices featuring the Lightning connector. Tested to endure strenuous wear and tear and winter and summer in-car use, the strong and rugged cable is a must-have for both business and consumer applications.
The durable USB C to Lightning cable has aramid fiber reinforcement that shelters it from the stress of frequent bends and twists. This also lets the heavy duty cable flex without over-stretching and strengthens the core of the cable.
Cable Key Features. Aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil with braided shielding. TPE (thermoplastic elastomer) cable jacket is softer and more flexible than a standard PVC cable and environmentally friendly.
The reinforced cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle. Plus, the improved inner molding resists cracking and reduces cable damage.
Connector Key Features. Lightning connector provides 12W so your charger can charge your iOS devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle.
Built for daily use
The durable USB-C to Lightning cable has aramid fiber reinforcement that shelters it from the stress of frequent bends and twists. This also lets the heavy duty cable flex without over-stretching and strengthens the core of the cable. -
Apple MFi-certified
USB-C to Lightning adapter cable for guaranteed fast and reliable charge/sync from USB-C charger port for lightning devices.
- StarTech.com 6 ft(2m) Durable White USB-C to Lightning Cable, Heavy Duty Rugged Aramid Fiber USB Type A to Lightning Charger/Sync Power Cord, Apple MFi Certified iPad/iPhone 12 Pro Max - iPhone 7/8/11/11 Pro - Lightning cable - Lightning / USB 2.0 - 2 m
- Cable
- American Wire Gauge (AWG)
- 22/32
- Length
- 2 m
- White
- Connector
- Lightning - male
- Connector (Second End)
- 24 pin USB-C - male
- USB / USB 2.0
- Sync and charge, strain relief, EMI/RFI protection, aramid fibre core
- 2-year warranty
- Cable Type
- Lightning cable
- Interface Supported
- 22/32
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- USB / USB 2.0
- Length
- 2 m
- Plated Connector
- Nickel
- Recommended Use
- Mobile phone, portable player, tablet
- White
- Connector
- Apple Lightning - male
- RoHS, REACH, MFI, EMI
- 1.2 cm
- 0.6 cm
- 35 g
- Shipping Width
- 7.5 cm
- Shipping Depth
- 16 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 40 g
- Limited warranty - 2 years
StarTech.com 2 m/6.6 ft USB C to Lightning Cable - Black | In Stock | £17.81 |
StarTech.com 1 m/3.3 ft USB C to Lightning Cable - White | In Stock | £16.19 |
StarTech.com 1 m/3.3 ft USB C to Lightning Cable - Black | In Stock | £6.26 |
