StarTech.com 2 m (6.6 ft.) VGA to HDMI Adapter Cable with USB Audio
Quicklinx: FMJ3WS00 Mfr#: VGA2HDMM2M
Length: 2m
15 In Stock
£30.45 ex VAT
£36.54 inc VAT
VGA to HDMI Converter with USB Audio 1920 x 1080 Resolution 2-Year Warranty. This 2 m (6ft.) VGA to HDMI adapter cable lets you connect the VGA output on your Desktop or Laptop directly to an HDMI input on a monitor, TV, or projector without any additional cords.
High Definition Video
The active VGA to HDMI converter adapts your VGA video output to accommodate the increasing number of displays and projectors that only support HDMI.
Not all VGA converters are created equal. This VGA to HDMI converter cable ensures you're harnessing the highest video quality from your VGA output, with support for resolutions up to 1920x1080 (1080p).
Hassle-Free Setup
For hassle-free setup the VGA (male) to HDMI (male) video cable, allows for plug-and-play installation. Plus, with a built-in USB power cable the device is powered using the USB port on your computer. The VGA to HDMI adapter will work with any computer operating system but when working with a Windows PC the adapter also supports native USB audio. This functionality allows you to output both sound & video over HDMI.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The VGA2HDMM2M is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • High definition video
  • Hassle-free setup
StarTech.com 2m VGA to HDMI Converter Cable with USB Audio Support & Power, Analog to Digital Video Adapter Cable to connect a VGA PC to HDMI Display, 1080p Male to Male Monitor Cable - Supports Wide Displays (VGA2HDMM2M) - adapter cable - HDMI / VGA / USB - 2 m
Cable
Adapter cable - HDMI / VGA / USB
Max Output Resolution
1920 x 1080 - 60 Hz
Length
2 m
Connectors
HD-15 (VGA) - male (input) , USB - male (input)
Connectors (Second End)
HDMI - male (output)
USB / USB 2.0
Active cable, 1080p support, USB power + audio
Cable Type
Adapter cable active, 1080p support, USB power + audio
Interface Supported
HDMI / VGA / USB
Jacket Material
Plastic
USB / USB 2.0
Length
2 m
USB powered, 7.1 PCM audio channel support, Micro Silicon MS9282 chipset, USB audio
Adapters & Converters
1920 x 1080
Refresh Rate
60 Hz
Connectors
15 pin HD D-Sub (HD-15) - male (input) , 4 pin USB Type A - male (input)
19 pin HDMI Type A - male (output)
Plug and Play, FCC, RoHS, WEEE, REACH
131.2 g
Shipping Width
21.8 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
136.2 g
Length: 2m
