StarTech.com 2 m (6.6 ft.) Laptop Cable Lock - Nano-slot
Quicklinx: FTWXWS00 Mfr#: LTLOCKNANO
Device Type: Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Silver/Black
£27.59 ex VAT
£33.10 inc VAT
This laptop cable lock gives you an easy and effective way to secure your notebook to a sturdy object and keep it safe from theft. With this 4-digit combination laptop lock, you can be confident your laptop and valuable data are well protected. You can ensure that your laptop, computer, monitor, docking station or other electronic device will be anchored safely to your workspace in just a few simple steps with this keyless 4-digit combo lock with security cable.
  • Strong and durable
    Featuring a vinyl-coated steel cable, this laptop lock is designed for effective theft prevention. The portable combination laptop lock also features a helpful reset procedure if the original combination is known.
  • Bends with ease
    The flexible steel cable bends easily to loop around a stationery post or object, protecting your laptop or docking station against theft.
StarTech.com 6.5' (2m) Laptop Cable Lock, Nano Slot Compatible 4 Digit Combination Security Cable Lock, Serialized Anti-Theft Vinyl Coated Steel Cable Lock for Nano Slot Computer/Device - Nano Slot Laptop Lock (LTLOCKNANO) - Compatible with Kensington - security cable lock - TAA Compliant
Security cable lock
Package Content
Hook-and-loop tie
Product Material
Vinyl-coated steel
2.83 cm 1.6 cm
Length
2 m
135 g
4 digit code, anti-theft protection, flexible steel cable
TAA Compliant
Security cable lock
Product Material
Vinyl-coated steel
Package Content
Hook-and-loop tie
2.83 cm
1.6 cm
Length
2 m
135 g
20 cm x 22 cm x 2 cm / 139 g
Security Cable Lock
Intended For
Notebook
Lock Type
Nano
Lock Method
Combination
RoHS, REACH
TAA Compliant
Limited warranty: - 2 years
FTWX StarTech.com Nano Laptop Cable Lock In Stock £31.28
FTWX StarTech.com Universal Laptop Lock, 3-in-1 In Stock £30.35
FTWX StarTech.com 25-Pack Universal Laptop Lock In Stock £577.84
FTWX StarTech.com 25-Pack Universal Laptop Lock In Stock £591.65
FTWX StarTech.com 25-Pack Universal Laptop Lock In Stock £627.35
FTWX StarTech.com Computer/Peripheral Lock Kit In Stock £31.93
FTWX StarTech.com Laptop Nano Cable Lock, 5ft In Stock £16.40
FTWX StarTech.com Universal Laptop Cable Lock In Stock £24.68
Device Type: Laptop
Type: Security
