Finding the right laptop lock to help protect against theft has never been easier. This universal 3-in-1 keyed laptop cable lock works with the common security lock slots. The interchangeable lock heads are compatible with three different laptop lock slots: Kensington K-Slot, Kensington Nano, and Noble Wedgelock. It's an ideal way to secure your laptop, such as HP Notebook PC or Dell XPS, or other devices such as monitors, docking stations, projectors, and drive enclosures.
The keyed design means you don't have to remember a combination, making enhanced security easy at the office or on the go.
Convenient push-to-lock function
Save time every day with the push-to-lock button. Just one press and the lock is set, without using the key. Plus, for convenient operation, the cable joint swivels 360 degrees. -
No combination required
Easily lock and unlock the laptop cable lock with the master keys provided. Two identical keys are provided, to ensure you always have a spare. -
Maximize security
Ensure that your laptop, tablet, dock or other device is anchored safely to your workspace. This keyed cable lock features a durable zinc-alloy lock head, to provide dependable theft protection in a wide range of retail, commercial, and institutional environments. -
Versatile use
Ideal for portable use or at the office, the computer cable lock features a locking cable made of vinyl-coated steel (4.4 mm diameter). To secure your device in a variety of different work spaces, the flexible steel cable bends easily to loop around a stationary post or object.
- StarTech.com 6.5' (2m) 3-in-1 Universal Laptop Cable Lock, Keyed Laptop/Desktop Security Cable Lock Compatible w/ K-Slot, Nano & Wedge Slot Computer, Anti-Theft Steel Cable Lock w/ Keys - Universal Laptop Lock - security cable lock - TAA Compliant
- Product Type
- Security cable lock
- Package Content
- Hook-and-loop tie, 2 x keys
- Product Material
- Vinyl-coated steel
- 2.66 cm 1.2 cm
- Length
- 2.03 m
- 130 g
- Nano slot keyed lock, noble wedge lock, kensington security slot, cut-resistant, anti-theft protection, K-lock security slot, 360° head rotation
- TAA Compliant
- 2-year warranty
- Product Type
- Product Material
- Package Content
- 2.66 cm
- 1.2 cm
- Length
- 2.03 m
- 130 g
- Shipping Dimensions (WxDxH) / Weight
- 12.8 cm x 20.5 cm 135 g
- RoHS, REACH
- TAA Compliant
- Limited warranty: - 2 years
StarTech.com Nano Laptop Cable Lock | In Stock | £31.28 |
StarTech.com Laptop Cable Lock 6Ft | In Stock | £24.79 |
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £27.58 |
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £30.15 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £507.39 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £587.62 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £627.35 |
StarTech.com 3-in-1 Universal Laptop Lock | In Stock | £26.89 |
StarTech.com Computer/Peripheral Lock Kit | In Stock | £31.72 |
StarTech.com Laptop Nano Cable Lock, 5ft | In Stock | £16.28 |
StarTech.com Universal Laptop Cable Lock | In Stock | £24.52 |
