This USB C cable withstands the daily demands of charging and syncing your mobile devices. Compatible with your Thunderbolt 3 ports, this rugged cable is a must-have for both business and consumer applications.
The durable USB C charging cable has aramid fiber reinforcement that shelters it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cable.
Cable Key Features. Aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil with braided shielding. TPE (thermoplastic elastomer) cable jacket is more flexible than a standard PVC cable.
The USB A to USB C cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle.
Connector Key Features. USB Type C connector provides 3A of power output for charging your USB C compatible devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle.
The durable cable supports all USB 2.0 specifications providing a dependable connection for all your USB-C devices. It also delivers up to 60W of power to charge your devices without needing an additional power supply.
Built for daily use
The durable USB-C charging cable has aramid fiber reinforcement that shelters it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cable. -
Superior connection
The durable cable supports all USB 2.0 specifications providing a dependable connection for all your USB-C devices. It also delivers up to 60W of power to charge your devices without needing an additional power supply. -
Fast charge and sync
Supporting up to 3A for fast charging from a USB-A port or Quick Charge power adapter, this high-quality cord is designed to charge and sync your USB-C devices.
- StarTech 2m USB A to USB C Charging Cable, Durable Fast Charge & Sync USB 2.0 to USB Type C Data Cord, Rugged TPE Jacket Aramid Fiber M/M 3A Black, Samsung S10, S20, iPad Pro, Pixel - Heavy Duty and Rugged - USB-C cable - USB to USB-C - 2 m
- USB-C cable
- Technology
- Double shielded
- Strain relief, EMI protection
- Cable Length
- 2 m
- Connector
- 4 pin USB Type A - male - straight
- Connector (Second End)
- 24 pin USB-C - male - straight
- Thunderbolt 3 / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2HDUACP2, SECTBLTDT, STNDTBLTMOB
- USB-C cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 22/32
- Plated Connector
- Nickel
- Cable Length
- 2 m
- Black
- 1.48 cm
- 0.7 cm
- 35 g
- Connector
- Thunderbolt 3 / USB 2.0, RoHS, REACH
- Shipping Width
- 16 cm
- Shipping Depth
- 7.5 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 40 g
- Designed For
StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black
