This USB to USB-C cable multipack lets you charge and sync your USB Type-C devices over long distances using the USB-A port on your computer or the standard USB-A wall charger.
Charge and sync your mobile devices
Maintain all your devices fully charged with these USB Type-C cables. -
Superior connection with USB-IF certified cables
The USB Type-A to Type-C cables have undergone rigorous compliance testing and are certified by USB-IF to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all your USB-C devices.
- StarTech USB to USB C Cable - 2 m USB 2.0 Type C Cable 10 Pack - USB-C cable - USB to USB-C - 2 m
- USB-C cable
- Packaged Quantity
- 10 (specifications are for single item)
- Sync and charge, braided
- Cable Length
- 2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Packaged Quantity
- USB-C cable
- Shielding Material
- Aluminum mylar foil
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Cable Length
- 2 m
- Black
- 710 g
- Connector
- USB / USB 2.0, RoHS, USB-IF, WEEE, REACH
- Shipping Width
- 25.5 cm
- Shipping Depth
- 33 cm
- Shipping Height
- 5 cm
- Shipping Weight
- 720 g
StarTech.com 30cm USB-A to USB-C Cable | In Stock | £4.62 |
StarTech.com 6in USB-A to USB-C Cable | In Stock | £4.60 |
