StarTech.com 2 m / 6.6 ft. USB to USB C Cable - 10-Pack USB A to C Cables
Quicklinx: FW6TWS00 Mfr#: USB2AC2M10PK
Length: 2m
£87.40 ex VAT
£104.88 inc VAT
This USB to USB-C cable multipack lets you charge and sync your USB Type-C devices over long distances using the USB-A port on your computer or the standard USB-A wall charger.
  • Charge and sync your mobile devices
    Maintain all your devices fully charged with these USB Type-C cables.
  • Superior connection with USB-IF certified cables
    The USB Type-A to Type-C cables have undergone rigorous compliance testing and are certified by USB-IF to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all your USB-C devices.
StarTech.com USB to USB C Cable - 2 m USB 2.0 Type C Cable 10 Pack - USB-C cable - USB to 24 pin USB-C - 2 m
USB-C cable
Packaged Quantity
10 (specifications are for single item)
Sync and charge, braided
Length
2 m
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
Packaged Quantity
USB-C cable
Shielding Material
Aluminum mylar foil
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Length
2 m
710 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS, USB-IF, WEEE, REACH
Shipping Width
25.5 cm
Shipping Depth
33 cm
Shipping Height
5 cm
Shipping Weight
720 g
Length: 2m
