StarTech.com 2 m / 6.6 ft USB C Cable – Black
Quicklinx: FL7KWS00 Mfr#: RUSB2CC2MB
Length: 2m
£10.86 ex VAT
£13.03 inc VAT
This USB C cable withstands the daily demands of charging and syncing your mobile devices. Compatible with your Thunderbolt 3 ports, this rugged cable is a must-have for both business and consumer applications.
The durable USB C charging cable has aramid fiber reinforcement that shelters it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cable.
Cable Key Features. Aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil with braided shielding. TPE (thermoplastic elastomer) cable jacket is more flexible than a standard PVC cable.
The USB A to USB C cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle.
Connector Key Features. USB Type C connector provides 3A of power output for charging your USB C compatible devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle.
The durable cable supports all USB 2.0 specifications providing a dependable connection for all your USB-C devices. It also delivers up to 60W of power to charge your devices without needing an additional power supply.
  • Built for daily use
    The durable USB-C charging cable has aramid fiber reinforcement that shelters it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cable.
  • Superior connection
StarTech.com 2m USB C Charging Cable, Durable Fast Charge & Sync USB 2.0 Type C to USB C Laptop Charger Cord, TPE Jacket Aramid Fiber M/M 60W Black, Samsung S10, S20 iPad Pro MS Surface - Heavy Duty and Rugged - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Double shielded
Strain relief, EMI protection, DisplayPort Alternate Mode support, up to 60 Watts of power delivery
Length
2 m
Connector
24 pin USB-C - male - straight
Connector (Second End)
USB / USB 2.0
P/N: CDP2HDUACP2, SECTBLTDT, STNDTBLTMOB
USB-C cable
Double shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Length
2 m
1.2 cm
0.62 cm
35 g
Connector
USB / USB 2.0, RoHS, REACH
Shipping Width
16 cm
Shipping Depth
7.5 cm
Shipping Height
3 cm
Shipping Weight
40 g
FL7K StarTech.com 1 m / 3.3 ft USB C Cable – White In Stock £8.89
FL7K StarTech.com 2 m / 6.6 ft USB C Cable – White In Stock £10.86
Length: 2m
