Extend your computer power connection distance by 2ft. The PXT1002 2-foot Computer Power Cord Extension Cable can be used to connect your PDU or monitor to your PC, or as an extension cable for your existing computer power cord.
Expertly designed and constructed of high quality materials, the power extension cable (C14 to C13) features one computer power (female) connector and one hooded (male) power connector.
- StarTech.com 2ft (60cm) Power Extension Cord, C14 to C13, 10A 125V, 18AWG, Black Computer Power Cord Extension, Power Supply Extension Cable, IEC-320-C14 to IEC-320-C13 AC Power Cable - UL Listed - power extension cable - IEC 60320 C14 to power IEC 60320 C13 - 60 cm
- Power extension cable
- Length
- 60 cm
- Connector
- Power IEC 60320 C14
- Connector (Second End)
- Power IEC 60320 C13
- Black
- Limited lifetime warranty
- American Wire Gauge (AWG)
- 18
- Length
- 60 cm
- Black
- Connector
- UL, RoHS
