StarTech.com 2 ft Panel Mount USB Cable A to A - F/M
Quicklinx: 9PS3WS00 Mfr#: USBPNLAFAM2
Length: 60cm
£5.12 ex VAT
£6.14 inc VAT
Add an external panel mount USB connection to a PC or faceplate. The USBPNLAFAM2 2ft Panel Mount USB Cable provides a well-secured, easy to access USB-A port on your PC or on a faceplate, allowing you to customize your systems to suit your needs. Perfect for podiums, kiosks and other solutions where added access to USB devices is required.
The adapter features one male USB-A connector and one female panel mount USB-A port and gives you an extension of 2ft, enabling you to place the cable as needed within the system case.
StarTech.com 2 ft Panel Mount USB Cable A to A F/M - Panel Mount USB Extension USB A-Female to A-Male Adapter Cable 2ft - USB-A (F) Port (USBPNLAFAM2) - USB extension cable - USB to USB - 60 cm
USB extension cable
Double shielded
Molded, thumbscrews
Length
60 cm
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type A - male
P/N: UUSBOTG
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Molded, thumbscrews
Length
60 cm
Connector
RoHS
P/N: UUSBOTG
9PS3 StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.93
9PS3 StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.02
9PS3 StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.04
9PS3 StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.29
9PS3 StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.49
9PS3 StarTech.com 3 ft Panel Mount USB Cable A to A - F/M In Stock £5.34
9PS3 StarTech.com 2 ft Panel Mount USB Cable A to A - F/M In Stock £5.12
Length: 60cm
