StarTech.com 2 ft Cat5e Red Snagless RJ45 UTP Cat 5e Patch Cable
Quicklinx: 8CDYWS00 Mfr#: 45PATCH2RD
The 45PATCH2RD CAT5e Patch Cable meets or exceeds all CAT5e specifications to ensure reliable Ethernet network connections, and features a durable PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality CAT5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
  • 100% copper - a better value
    StarTech.com CAT5e cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG wire
    This CAT5e cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
    This RJ45 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com Cat5e Ethernet Cable - 2 ft - Red- Patch Cable - Snagless Cat5e Cable - Short Network Cable - Ethernet Cord - Cat 5e Cable - 2ft (45PATCH2RD) - patch cable - 0.6 m - red
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Snagless
Length
0.6 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Snagless
Length
0.6 m
Red
Connector
RJ-45 - male
RJ-45 - male
UL
