StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
Quicklinx: 5D3KWS00 Mfr#: HSB220SAT25B
17 In Stock
£44.84 ex VAT
£53.80 inc VAT
Easy, trayless removal and insertion of dual 2.5in SATA hard drives from single 3.5in bay. This 3.5in SATA hard drive hot-swap bay allows you to install two 2.5in SATA hard drives (HDD) or solid state drives (SSD) in an available/unused 3.5in floppy drive bay.
Featuring a convenient "no mounting required /easy eject" feature (like a tape cartridge or floppy disk), the hard drive hot swap bay doesn't require that the drives be installed in a tray - making it the ideal solution for quick and easy drive removals and insertions as part of a system building process, or integration into rackmount systems or industrial environments.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
Also a perfect addition for operating system image deployment and any task that requires being able to quickly access large volumes of data on the fly, the hot swap bay provides everything you need to expedite important projects while maintaining a reliable storage solution.
With support for SATA HDD speeds up to 6.0 Gbps, this backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
  • Efficient hot-swap capability
    The hot-swap functionality allows users to replace or add drives while the system remains powered on, minimizing downtime and enhancing workflow efficiency.
  • Robust aluminum design
    Constructed from aluminum, this mobile rack is built to withstand regular use while providing effective heat dissipation, ensuring optimal performance for installed drives.
  • Versatile connectivity options
    Equipped with multiple Serial ATA connectors, this storage bay adapter provides flexible connection options for integrating with various systems and setups.
  • Space-saving solution
    Designed to fit within a standard 3.5-inch bay, this mobile rack optimizes space utilization, allowing for efficient storage management in compact environments.
  • Compliance with safety standards
    Meeting FCC and RoHS requirements, this product promotes environmental responsibility and safety, making it a conscientious choice for data storage needs.
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane - Dual Drive SATA Mobile Rack Enclosure for 3.5 HDD (HSB220SAT25B) - storage bay adapter
Storage bay adapter
Expansion Bays
2 x hot-swap - 2.5"
Compatible Bay
1 3.5"
Product Material
Aluminium
10.2 cm x 13.4 cm x 2.4 cm
283 g
Storage bay adapter
Product Material
Aluminium
Storage Controller
No CPU
Bays
2 x hot-swap - 2.5"
2 x SATA 3Gb/s - SATA power , 2 x SATA 3Gb/s - SATA
2 storage - Serial ATA-300 - 15 pin Serial ATA power , 2 storage - Serial ATA-300 - 7 pin Serial ATA
Compatible Bay
1 x internal 3.5"
FCC, RoHS
10.2 cm
13.4 cm
2.4 cm
283 g
5D3K StarTech.com 24" Serial ATA Cable In Stock £5.28
5D3K StarTech.com 18in SATA Serial ATA Cable In Stock £2.41
5D3K StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.88
5D3K StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £17.75
5D3K StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £44.84
5D3K StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot In Stock £26.41
5D3K StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £69.01
5D3K StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £84.20
5D3K StarTech.com 5.25 to 3.5 Drive Hot Swap Bay In Stock £29.81
