StarTech.com 2-Bay 3.5" HDD Enclosure, RAID
Quicklinx: CWBDWS00 Mfr#: S352BU313R
Type: Hard drive Array
HD Size: 3.5
Power Supply: Power adapter
£93.39 ex VAT
£112.06 inc VAT
Create high performance external storage with a dual SATA HDD RAID array, through USB 3.1 (10Gbps). This USB 3.1 dual-bay drive enclosure makes it easy to add high-capacity, high-performance external data storage to your laptop or desktop computer. The dual-bay RAID enclosure supports two 3.5" SATA hard drives with ultra-fast data transfer speeds and configurable RAID modes.
Create a high-capacity, external data storage solution with support for two 3.5" HDDs, SSDs or SSHDs. This 2-bay 3.5" drive enclosure delivers fast file transfer rates up to 10Gbps with USB 3.1 Gen 2 performance. It supports SATA I, II and III and is enhanced with UASP to maximize the performance and speed of your SATA III drives.
The dual-drive RAID enclosure provides an effective solution for creative professionals, office employees, researchers, and medical personnel to store, access, back up, and protect important files. It gives you the peace of mind of knowing that your data is safe, secure, and protected.
With multiple RAID options, you can gain increased storage size, performance, or redundancy. The enclosure supports RAID 0, RAID 1, JBOD and SPAN (BIG), which enables you to choose your preferred backup mode and customize your drive arrangement based on your storage requirements.
To maximize both durability and reliability, the external RAID enclosure features an aluminum and plastic housing with a metal hard-drive mounting tray. It also features a built-in fan, to help dissipate operating heat and maintain an optimum operating environment for drive protection.
The dual-bay drive enclosure includes both a USB-C and USB-A cable for flexible use with the latest laptops and tablets, equipped with a USB-C port, Thunderbolt 3 USB-C port, as well as legacy devices. The enclosure is OS independent, requiring no additional software or drivers.
StarTech.com 3.5" External Dual Hard Drive Enclosure - Raid - USB-C and USB-A - SATA 6Gbps - 2 Bay USB 3.1 SSD/HDD Enclosure (S352BU313R) - hard drive array
Hard drive array
Max Supported Capacity
10 TB
USB 3.1
0 (installed) / 2 (max)
Supported Drives
SATA-600
Australia, Japan, North America, United Kingdom, Europe
Storage Controller
RAID (SATA 6Gb/s) - RAID RAID 0, 1, JBOD, BIG
AC 120/230 V
7.5 cm x 19 cm x 12.5 cm
1 kg
P/N: TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
Hard drive array
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
2
Supported Drives
SATA-600
Storage
10 TB
HDD Array External Interface
USB 3.1
CPU
1 x ASM1352R
Storage Controller
RAID (SATA 6Gb/s)
Channel Qty
2
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
Expansion Bays
2 (total) / 2 (free) x internal - 3.5"
1 x USB 3.1 - 9 pin USB Type B
LED indicator, built-in cooling fan, UASP transfer protocol, tested with up to 10TB, TRIM support
1 x USB-A to USB-B cable , 1 x USB-C to USB-B cable
MTBF
100,000 hours
FCC, RoHS
Stand, screws
External power adapter
AC 120/230 V
36 Watt
7.5 cm
19 cm
12.5 cm
1 kg
5 - 95%
CWBD StarTech.com 1m USB 3 Cable Right Angle BK In Stock £6.63
CWBD StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.86
CWBD StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £29.35
CWBD StarTech.com USB 3.1 Enclosure with USB-C In Stock £25.00
CWBD StarTech.com M.2 SATA Enclosure with USB-C In Stock £28.99
CWBD StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £17.80
CWBD StarTech.com 4 Bay SSD/HDD Docking Station In Stock £144.99
HD Size: 3.5
