StarTech.com 2.6ft/80cm Thunderbolt 5 Cable
Quicklinx: J4LXWS00 Mfr#: TBLT5MM80CM240W
Length: 80cm
29 In Stock
£30.97 ex VAT
£37.16 inc VAT
Experience reliable, ultra-high performance between Thunderbolt 5-enabled devices, supporting up to twice the bandwidth of Thunderbolt 4, 8K 60Hz video, and 240W charging over a single connection. This Thunderbolt 5 cable is ideal for high-performance laptops such as 16in MacBook Pro with M4 Pro/Max. Thunderbolt 5 delivers bidirectional bandwidth of 80 Gbps, evenly distributed across its data lanes for consistent high-speed performance in both directions. When higher display bandwidth is required, the cable's Boost Mode reallocates the data lanes, enabling 120 Gbps of bandwidth in one direction (transmit) while maintaining 40 Gbps in the other (receive). This asymmetric configuration is ideal for display-intensive tasks, such as driving multiple 8K monitors or handling high-resolution video workflows, while still supporting robust data transfer capabilities. For seamless operation between Type-C Thunderbolt-enabled devices, the Thunderbolt 5 Cable is Thunderbolt-Certified for guaranteed Thunderbolt 5 performance and backward compatibility. Certified cables provide consistent, reliable performance across multiple resolutions, refresh rates, and resource-intensive applications. The Thunderbolt 5 cable features a flexible TPE outer jacket that is tested to withstand 2,000 bending cycles at -/+90 degrees, and routes easily around corners and desk edges. Robust strain reliefs enable convenient positioning of the cable. The durable Nickel-plated connectors are rated to operate beyond 10,000 insertions. This Certified Thunderbolt 5 Cable supports full Thunderbolt 5 performance, including 80 Gbps bidirectional bandwidth, doubling the capacity of Thunderbolt 4; DisplayPort 2.1 Alt Mode: Up to 8K 60Hz/4K 240Hz video with DSC, HDR, and 10-bit color; PCI Express 4.0 (64 Gbps) support for GPUs, NICs, and storage in PCIe chassis; 240W Power Delivery EPR for charging for high-performance laptops, and backward Compatibility with Thunderbolt 4/3, USB4 (40 Gbps), and USB 3.2 (10 Gbps) This versatile Thunderbolt 5 cord is constructed with braided alloy shielding to minimize EMI for seamless and consistent data/video output and long-term reliable performance.
  • Enhanced Bandwidth with Boost Mode
  • Seamless Compatibility
  • Durable Design
  • Supported Thunderbolt 5 Features
    This Certified Thunderbolt 5 Cable supports full Thunderbolt 5 performance: • 80 Gbps bidirectional bandwidth, doubling the capacity of Thunderbolt 4 • 120 Gbps boost mode for display-intensive applications • DisplayPort 2.1 Alt Mode: Up to 8K 60Hz/4K 240Hz video with DSC, HDR, and 10-bit color • PCI Express 4.0 (64 Gbps) support for GPUs, NICs, and storage in PCIe chassis • 240W Power Delivery EPR for charging for high-performance laptops • Backward Compatibility with Thunderbolt 4/3, USB4 (40 Gbps), and USB 3.2 (10 Gbps) This versatile Thunderbolt 5 cord is constructed with braided alloy shielding to minimize EMI for seamless and consistent data/video output and long-term reliable performance.
StarTech.com 2.6ft (80cm) Thunderbolt 5 Cable, 80Gbps/120Gbps, Certified - Thunderbolt cable - Thunderbolt 5 to Thunderbolt 5 - 80 cm
Thunderbolt cable
Passive adapter, 4K support, 8K support, USB Power Delivery (240W), extended power range (EPR), 10-bit deep colour, 80 Gbps data rate, Display Stream Compression (DSC), DisplayPort Alternate Mode 2.1 support, EMI protection, halogen free, HDR support, Intel certified, strain relief
Length
80 cm
Connector
Thunderbolt 5 - male
Connector (Second End)
USB4 / Thunderbolt 3 / Thunderbolt 4 / Thunderbolt 5 / DisplayPort 2.1
Thunderbolt cable
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30/34
Plated Connector
Nickel
Length
80 cm
Outside Diameter
4.6 mm
38 g
Connector
USB4 / Thunderbolt 3 / Thunderbolt 4 / Thunderbolt 5 / DisplayPort 2.1, RoHS, FCC
Shipping Width
12.8 cm
Shipping Depth
22 cm
Shipping Height
2 cm
J4LX StarTech.com 3ft (1m) Thunderbolt 5 Cable In Stock £32.51
J4LX StarTech.com 1.5ft/50cm Thunderbolt 5 Cable In Stock £29.30
J4LX StarTech.com 2.6ft/80cm Thunderbolt 5 Cable In Stock £30.97
J4LX StarTech.com 3ft/1m Thunderbolt 5 Cable In Stock £32.24
J4LX StarTech.com 1.5ft/50cm Thunderbolt 5 Cable In Stock £30.73
J4LX StarTech.com 2.6ft/80cm Thunderbolt 5 Cable In Stock £32.09
Length: 80cm
